Question about Brother DCP-7040 Laser Printer
I replace and reset the drum on my dcp 7040 but now the paper is smudging
aomcopier
  • 22 Answers
SOURCE: printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Posted on Mar 31, 2007
  • 3 Answers
SOURCE: Brother DCP-7020 Drum problems
Open the front of the printer by pulling on both tabs at the finger grips on both sides of the front panel. The front panel will flip down. The drum and toner cartridge comes out as a single unit. It is black plastic within gray plastic and has a handle like grip in the middle. Grasp this grip and pull the unit up and out. It feels kinda funny the first time you do it and you may feel like it will break, but it won't. Pull it up and out in a kinda circular arc. Do not touch the drum. If you ever need to replace the toner cartridge, press on the blue tap and separate the drum from the toner cartridge. You will have to replace the drum after every five toner cartridge replacements so practice doing it now. Note the tabs and slots on the sides before separating the drum and cartridge. Align the cartridge into the drum carriage and slide it in until it clicks. To replace the cartridge assembly into the printer, angle the cartridge at about 45 degrees and rotate in while pushing. It should click into place. If the front door then closes properly, you should have it in properly. Practice a few times and you should be an expert. For paper jams, there are many places to check and they may not all give warnings. First pull out the paper tray and check for and remove misfeeds. Remove the drum cartridge assembly and described here and check for and remove any paper. Open the back cover and check for and remove any paper. Open the automatic feed and check there as well as lifting the cover where the scanning surface is. Look in the rollers for the automatic feed for paper pieces. The last place almost never gives you a warning. Reach into the slot where the paper exits after being printed and grasp the whole top cover. Lift upward and it will open about 4 inches. This is a good place where small pieces of paper or even whole sheets may get stuck. Clean out any dust while you are there.
Posted on Oct 04, 2007
SOURCE: Reset Drum
Take it out and put it back in - the trick is to LEAVE THE FRONT DOOR OPEN after you put it back in. With the door still OPEN push the "options" button and you will be prompted for "New Drum?" and then push the "Up" button for 'Yes' and "Accepted" will appear on the lcd screen - and then the drum counter will be reset. The directions in the book work great - but you have to be careful make sure the door is still open when you push the "options" button...
Posted on Nov 22, 2008
wheatlandsvc
  • 1110 Answers
SOURCE: how reset drum page counter brother dcp-7040
This works for my DCP-7020, so it may work on the 7040.
If your drum is still good - take it out and put it back in - the trick is to LEAVE THE FRONT DOOR OPEN after you put it back in. With the door still OPEN push the "options" button and you will be prompted for "New Drum?" and then push the "Up" button for 'Yes' and "Accepted" will appear on the lcd screen - and then the drum counter will be reset.
Posted on Oct 20, 2009
komguy
  • 2306 Answers
SOURCE: Toner Life End message on DCP-7040
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
Posted on Jan 04, 2010
How do you replace the drum for a DCP-7040 brother printer
The drum is the the part where the the toner is attached to it , I replace mine once a year, I use it a lot, to reset the Drum Open the toner cover on the printer press Clear/back then press up /+ button good luck ce045b2c-0a6a-4f93-aca7-1409863e8241.jpg
May 29, 2014 | Brother DCP-7040 Laser Printer
Brother MFC-7040 smudging
try replacing the drum unit.If that doesn't work look at replacing the fusing unit.there may be a blue slider on the front top of the drum unit;if so slide it back and forth 3 or 4 times making sure it is left in the same position as when you started.
Apr 16, 2014 | Brother DCP-7040 Laser Printer
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay.
As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.
I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N.
So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.
DCP-7040 USER GUIDES: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=dcp7040_us_as&c=us&lang=en&flang=all
Apr 23, 2012 | Brother MFC-7340 All-In-One Laser Printer
When i first start my copies on my brother dcp 1000 they are clear by the time i get to copy 20 their are dark ink smudges on the paper. It seems when the copier starts heating up they smudges happen. I...
replace the drum,
( if you have used correct toner for refill because some time it happens if two different type of toner mixed up hence assuming that you have select gud toner).
vote me if found helpful.
Aug 17, 2011 | Brother DCP 1000 All-In-One Laser Printer
My printer dcp 7040 keeps telling me DRUM ERROR troubleshooting... How can i fix this??
Sounds like you will need to replace the drum. You can order a drum kit from Grand and Toy or from the Brother website. There are also many other websites you can order a drum kit from. Once the Drum unit is replaced your printer will start working again.
For a cheaper solution you can always reset the drum kit making the printer believe that the drum kit was replaced. For this you might need the manual.
Hope this helps
Mar 07, 2011 | Brother DCP-7040 Laser Printer
Could i reset the drum life of dcp 7040. it is factory set for 12000 copies as per the manual
Good Luck and Thank You for usig Fixya.
WheatlandServices
Dec 19, 2010 | Brother DCP-7040 Laser Printer
How to check the toner level of Brother printer
It has no accurate measure of the toner left, it is reset when you put in a fresh toner and just counts prints. The Brother shines a light thru a little window from right to left and when the toner is empty the light shines thru and it says it's empty.
Jan 13, 2010 | Brother DCP-7040 Laser Printer
How reset drum page counter brother dcp-7040
Oct 20, 2009 | Brother Office Equipment & Supplies
Brother DCP-7040 Laser Printer Logo
19 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
