Question about Proscan 7-Inch Android Internet Tablet, Capacitive Touch Screen, Android 4.1 Jelly Bean, with Included Case and Keyboard
Gravity calibration utility
How do i calibrate the accelerometer sensor calibration. tje touchscreen is off half an in from my finger
My rca 7" tablet(RCT6773W42B) I think needs to have the touchscreen recallibrated. A few days ago for no reason there is about 3/4's of an inch around three sides, and about three letters are dead
Go into your device's settings menu and find a touchscreen calibration option. Run the calibration and the device should more accurately be able to read your presses
May 19, 2017 | Tablets & eReaders
How do i calibrate my nextbook tablet
You can adjust the touchscreen calibration by going to Settings-->Touchscreen calibration on your Nextbook.
Jun 20, 2015 | Nextbook Tablets & eReaders
Having trouble trying to figure out how to do the touch screen calibration
Touch screen is not supposed to be "calibrated" by users. All my family uses touchscreen smartphones and computers and NEVER anyone mentioned the need of calibrating a touchscreen. If you have some problem with your touchscreen, it is something beyond standard devide operation and you should take it for service, if it is on warranty, to site where it should be serviced
Apr 12, 2015 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Touch screen calibration utility
Try using another app for touch screen calibration.
Jul 28, 2014 | Coby Kyros 7" Touchscreen Tablet
Compass
I'm not 100% sure (I'm a new Nexus 7 owner), but I have see some solutions out there. The consensus seems to be that the accelerometer or the magnetometer isn't properly calibrated.
There are apps out there which claim to calibrate your device sensors, but sometimes these apps need to remain open. Compass is often recommended.
The best (and most odd) solution I've heard is to have the app open and wave the nexus 7 around in a figure 8 pattern. Apparently this does some "voodoo magic" and the device seems to calibrate itself.
Lastly, I have also read that android compasses never seem to point to true north in apps like Google Sky, but is more apparent in larger devices.
If that doesn't help I would suggest contacting Google Support to see if there is a better solution or if they can swap it out.
Phone Number: 1-855-83-NEXUS (63987)
Best of Luck!
Dec 19, 2012 | Google Nexus 7
What does calibrating a ipad mean
Whoever used the term "calibrating an iPad" may have been referring to touch screen calibration.
Some touch screens need to be adjusted, or "calibrated", or the device may act as if you touched a different spot on the screen than you did. The iPad screen does not need to be calibrated.
If the iPad make a mistake about what spot you touched, the error may be due to:
  • a defect or damage;
  • a screen protector;
  • a cold finger;
  • a hand that is holding the iPad and inadvertently touching the screen;
  • a finger that is inadvertently touching the screen.
Apr 26, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Ello My problem is when i boot after a factory reset i have touchscreen to calibrate and when i do it it gives me try once again it's stuck there
I am not sure you are talking about a tablet PC or the new craze of tablets.
For the tablet PC you should have a screen calibration utility. You can calibrate the display for the Wacom (or other) pen, or for the touch input.
When you calibrate the pen, any touching of the screen with anything other that the Wacom pen will be ignored.
Similarly, when you calibrate the touch, any input with the Wacom pen will be ignored and you will be asked to use the proper instrument.
To get back to your case , it is possible that you are not putting the finger at the right place or not pressing hard enough. That is just a guess and I may be off the mark for the new tablets, but not for the Tablets PC:
Apr 07, 2012 | Tablets & eReaders
The touchscreen only works on the bottom of the screen (when its open normally the keyboard side)
Go there :
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
Choose your model, OS, language.
Download the calibration utility pertaining to your model (Touchscreen or Digitizer).
Sep 07, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic Toughbook CF-30 Touchscreen Calibration
Your touchscreen is defective. Please contact Panasonic official service center http://heartlandsi.com to arrange a repair. It's covered under warranty.
Sep 14, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Proscan 7-Inch Android Internet Tablet, Capacitive Touch Screen, Android 4.1 Jelly Bean, with Included Case and Keyboard Logo
144 people viewed this question
Top Proscan Tablets & eReaders Experts
tosin_christ
David Payne
David Payne
EE Eddie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
