Question about Xerox WorkCentre XD100 All-In-One Laser Printer
The XD100 is flashing CH
Xerox XD100 is flashing CH error code
flopez
  • 161 Answers
SOURCE: xerox printer xd100
H4 is a power failure code. To reset the error please press in the following order: CLR - AUTO - CLR - AUTO (this puts the unit in tech mode). Enter 14 (as if asking for 14 copies) Press "PRINT" Your unit should reset itself and start working.
Posted on Oct 02, 2007
  • 171 Answers
SOURCE: xerox xd100
See this thread, someone with a similar problem to you:
http://www.fixyourownprinter.com/forums/laser/24105
I'll summarize the solution:
The "software" H4 problem is quite common that Xerox has a resolution on its website
Solution: Perform a Fault Reset 14
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
1. Find the pink Clear button on the Control Panel of the WorkCentre.
2. Find the button below the word Auto.
3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
5. Press the green [Start] button.
6. Press the pink [Clear] button two times.
7. The WorkCentre should now warm up and come to ready.
8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Feb 08, 2008
  • 239 Answers
SOURCE: Xerox XD100 that is showing a code J2
If this code just came on, you have about 2,000 copies to run before the machine completly will not run.
This machine will run so many copies before it end of lifes the drum unit.
In the old days, these drum units were serviced by the service representative.
Nowdays, the cartridge just runs to the end of life on the cartridge. Most cartridges will run for about 15k with 2k to use to allow the user to order a cartridge.
Even if the cartridge is still good, the cartridge is end of life at the maximum allowed copies on the crum.
If the problem still exists with a new cartridge, the service repair for this is more involved and needs a service manual and someone who knows what they are doing to do the service in diagnostics mode.
I have preformed this many times before.
The NVM settings need to be rechecked and the main board may need to be reset.
Very involved.
Place a Xerox service call to have this repaired.
Posted on Oct 23, 2009
techman007
  • 1112 Answers
SOURCE: J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Posted on Dec 15, 2009
SOURCE: Xerox XD100
I have a XD100 Work Center with a L6 error code indication. After press "C" Clear (orange color button), followed by "Auto" (the most left small button) - exposure mode key; and "C" followed by "Auto" again, the copier starts to print and solved problem.
Posted on Feb 09, 2010
I have a xerox workcenter XD102 with a J1 error. What do I need to do?
J1 code on the XD100 series means that your toner cartridge is empty. You will need to order in a new one or have your existing cartridge refilled. Refills run about $60.00 and new ones are in the $100 to $125 range.
Precisionroller.com has a very good remanufactured unit for $46.00
http://www.precisionroller.com/search.php?q=xd100+toner
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
My xerox worcentre 103f shows the errors e7 - 15 where can I get a list with the code
The error code e7-15 is a copy lamp problem. There is a list of error codes for the Workcentre 100 series at this link.
http://www.partsdrop.com/pages/XD100inf.html
Jun 10, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
J2 error on xerox xd 100 copier
hello there:
here is a link that will be able to help you out
  1. XD100 Style: Trouble Shooting Xerox brand models: XD100/102/103/104/105, XD120/122/125/130/155, XL-2120/2130 ... Next month, we'll hit the J1 & J2 codes as well as the L codes...www.enxmag.com/OLD SITE/bhorvat2304.html - Cached
Sep 14, 2009 | Office Equipment & Supplies
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
WorkCentre XD100
http://www.nodevice.com/manual/newmans/XD100-102-104smpdf/get11486.html go here
Nov 15, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox copier XD100
Does the machine sit there and run and run and run. The motor turns on and just chugs away or simply the ready light flashes? Let me know which symptom so I can send you some things to try.
Oct 22, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox printer xd100
Sep 24, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
18 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
