Question about Nespresso Coffee Makers & Espresso Machines
Krups disassemble Leaking pixie
Fixing a leaking Krups XP2010
i have only read the first bit but the problem is that were you have the coffee filter holder you also have a seal which you have to change
Oct 15, 2014 | Krups XP2010 Combination Unit; 10 cup...
How do I disassemble Krups dolce gusto KP5000 machine?
You will need an instruction manual, if you leave your email address I will send it as a PDF file.
Oct 08, 2014 | Krups XP Coffee Makers & Espresso Machines
Nespresso d300 leaking
The disassembly is a bit tricky as there are some screws with oval heads that require special tooling.
The web site below has tons of useful information on how to do it and where to find the special tool for the oval-head screws.
http://maultech.com/chrislott/blog/20100627_nespresso.html
The tool is available on ebay for about $10.
http://www.ebay.com/itm/Nespresso-Krups-Service-Repair-Tool-Open-Security-Oval-Head-Screws-/121114184054
I managed to disassemble it by cutting a slot for a flat-head screw driver in the oval screws using a Dremmel tool.
Most of the screws that you have to remove are on the back of the machine. There are three special oval head screws + four torx-head screws + two Phillips screws on the top of the machine.
Feb 06, 2014 | Nespresso D300 Espresso Machine
Leaking Krups xp 7200 Coffee Maker
It is a Torx T15 screw. Common leak point on those is the barista seal at the bottom of the brewing chamber but that is by no means the only leak point. You need to get the covers off with your new Torx driver and see where the leak is
Apr 01, 2013 | Krups XP Coffee Makers & Espresso Machines
Krups xp 4050 leaks water under unit when sitting on counter
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Jun 13, 2010 | Krups Small Appliances Espresso Machine
How to remove casing of Krups XP7220
Hey there! I just got my XP apart. I need to replace my plunger due to leakage also. Can you tell me where you found one?
Do you have a service manual? Thanks, Trig
Apr 01, 2010 | Krups XP7230 Compact Super Automatic...
Leaks from bottom
Nov 14, 2009 | Krups Aroma Control 229 Coffee Maker
Bunn coffeemaker leaking
Is this a Bunn or a Krups-you have both listed.
Aug 09, 2008 | Krups Small Appliances Espresso Machine
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
