Question about HP Pavilion 2000-363NR Notebook Pc
Says I am not connectable for reason code 0x00028006
When I try to connect to router, it says I am not connectable due to reason code 0x00028006.,
Wireless association failed due unknown reason
There's always a reason but who cares if there is a good solution. Try rebooting your wifi router and then your PC and see if the connection returns. Also try to delete your WIFI network connection. Then reboot and it should return and so may your connection! If its a secure connection check if your password is correct by opening your WIFI network connection by double clicking it and clicking on wireless properties and then the security tab. Confirm your security key exists and is correct.
Sep 03, 2014 | Microsoft Windows Vista Home Premium with...
Cant connect to internet
Check your all physical connection and cable..
First,restart your computer
->Open web browser and enter the IP address and enter the login details on the login screen and proceed.Click Router Status under Maintenance and check if you see your IP address.
->If you see 0.0.0.0, the router is not obtaining the IP address. It can happen due to various reasons. Contact your ISP and ask for the details including username, password for PPPoE etc. and try to connect to the Internet again afterwards.
->After configure you router ,open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway
->If you are still unable to browse the Internet, ping your router's connection to the PC. Open Command Prompt, type 'ping IPaddress(ex:192.168.1.0)', hit Enter.
->If you get the Request timed out message then check your router connection again and correct the Ethernet connection between your PC and the router.
If you need any technical help on wireless router then you can reach at http://www.vtechsquad.com/
Feb 20, 2013 | Computers & Internet
I dont know how to get wireless internet
Check the ADSL or cable modem status light. If it is solid green, it indicates that your ADSL/cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring.
When done, log in to the web interface of your router device and check if it can obtain the IP address from your ISP or not.
You may also need to configure the default gateway settings also. To configure your router device as the default gateway, reboot your PC. When done, open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway
The Request timed out error can occur due to two things: (1). incorrect physical connection between your router device and the PC or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
When done, check back if you can browse the Internet or not.
***If you need any kind of technical assistance you can contact support cell
Jan 21, 2013 | Computers & Internet
I try log on it says check your connection but I have full bars
->Check the ADSL or cable modem status light. If it is solid green, it indicates that your ADSL/cable modem has a good connection.
->Verify that the Internet light on your wireless router is solid or blinking green. if all light is on then it is connected otherwise it will give the connection error.
->You can also check router status under Maintenance after login the router.And you will see the IP address .If you see 0.0.0.0, the router is not obtaining the IP address. It can happen due to various reasons. Contact your ISP and ask for the details including username, password for PPPoE etc. and try to connect to the Internet again afterwards.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 15, 2012 | Computers & Internet
Why do I get an error code when trying to download a game to my Wii Memory?
Any time I have tried to download from Nintendo Shopping channel, I have gotten an error for one of a few reasons. 1. No Internet Connection. 2. Slow Connection, 3. Connection Drop. or 4. operating system error.
If you provide the error code or look it up on Nintendos website, it usually gives your some hints to fix your issue.
However, here are the most common:
1. This is usually because the WII console is not connecting to the router or getting an IP address. If could also mean your router has lost its connection to the internet (easily checked with any other computer).
2. This is usually due to congestion (per Nintendo) in your area. They say to try changing your channel for the router. I think Nintendo recommends 6 or 11 but it depends on how many people in near you use wireless.
3. This can be a number of things. This time of year, you typically have problems accessing/downloading things from Nintendo just because a lot of people are trying. However, I have wireless N and the WII is wireless G; I have found that sometimes causes drops. Wireless N is constantly trying to get the best signal and sometimes changes channels (at least mine does), this can cause G to drop sometimes. I went to a wired solution, it helps in online play.
4. I have not seen this one of late. But when WII first came out, an update disabled WII connect and Nintendo had to replace the unit.
Jan 01, 2010 | Nintendo Wii Console
I bought this router 2 days ago. I pluged in the phone socket (with micro filter), and into mains,it worked perfectly on my daughters' (each daughter has a laptop - all work)laptops, and one of my desktop...
1) Make sure there is no low-pass filter from the phone line to the wall - it should be directly connected.
2) The laptop issue has nothing to do with the wireless router if it's actually connected. Try pinging the router. Open the command prompt. type ipconfig. Look at the laptop's IP address and the gateway. Try pinging the gateway (ie ping 192.168.1.1). If the ping works, the connection is fine.
3) Can you open a browser window but not connect to a web page? This is due to a connectivity issue. If you can't even open a web page for whatever reason, its a problem with the laptop, not the connection. Hope this helps.
Nov 08, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Hey there. I have an msi router model: NO:RG606 For some reason only me, being the main user of the router can connect to the internet. My other buddy in my house cannot connect although there is good...
login to the router interface make sure there is not a block for anyone else to use it and the playstation you have to enter the wep code or whichever the encryption you used
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Feb 17, 2009 | MSI Wireless-G RG54G3 Router
Belkin Pre-n wireless router
Check your device to see if it is due for a firmware upgrade. Esp. depending on your ISP, log into your device that you have from your ISP ( whether dsl modem, cable modem, etc.) and then follow whatever procedure it needs to determine your current firmware version.
Jun 16, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
HP Pavilion 2000-363NR Notebook Pc Logo
211 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
