Question about Cameras
Three lights flashing on scissorlift model hb600-24b
Three lights flashing on charger
When I put a battery on the charger either only the red light flashes or all three lights stay on steady. what can I do to fix this problem
The flashing red means a short, or bad battery. It is not 100% accurate. Sometimes you can leave the battery on the charger for an hour or so and pull and reinsert it and it will charge. Check: battery at room temperature, then battery contacts on both the battery and charger. Clean them. Power cycle the charger, which was unplugged when you cleaned it, right? Sometimes, a pocket will go bad. The 3 lights I do not know about.
Oct 26, 2015 | Motorola NTN1177 Rapid Multi Unit Charger,...
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
Jazzy 1133 has new batteries. All lights are lit on the battery condition meter. Maximum speed/profile indicator constantly blinks no matter how many sements are lit. After I turn it off and waiting a...
If all lights are flashing excessive voltage has been applied to the controller system. 6 flashing lights on the 1133 indicates that the chair is being inhibited by the battery charger. Try unplugging the battery charger. Check you battery connections.
Mar 30, 2013 | Pride Jazzy 1113 Power Chair
Green and red light flashes on my panasonic impact driver charger
You didn't state which model charger or tools you have so I cannot find specifics on your charger. In all the chargers I've worked with and on, if both lights are flashing it usually means the battery is being read as defective and the charger won't charge it.
Jan 14, 2013 | Drills
Makita DC18RA Makstar Li ion Charger three lights
Alternate Red and Green flashing means bad battery. Buy a new one, or take it to a Makita Service center for replacement if it's under warranty.
Normally the yellow light indicates hot battery, but it could also mean dirty battery contacts so the heat sensor can't be read, or that the fan is clogged with dust and unable to cool the battery. The manual says let the battery cool and try again. If the yellow still flashes, it's contacts or the fan.
Read the manual online at:
http://www.makita.ca/data/upload/accessorypbim/417_im_english.pdf
Oct 28, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have olympus camera battery charger, it charges a battery then when the next battery goes in the light keeps flashing it should be solid light
three things to try.. reverse polarity on the charger (turn the plug around), clean the copper contacts on the battery and charger, get a new battery
May 20, 2011 | Digipower Travel Charger for Select...
My porter cable 19.2v model 8605 battery charger
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Jul 24, 2010 | Porter Cable 19.2V Drill Kit
Power on Board 450 portable charger light - green flashing
What your seeing there is indicating fully charged.
Apr 01, 2010 | JUMP START SYSTEM
Cameras Logo
48 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
