Question about Morphy Richards Irons
42244 no steam
Steam coming from the base but not from the iron
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
DiYerTech
  • 70 Answers
SOURCE: no steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Posted on Jul 21, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Swan steam iron
The iron has failed and is leaking steam where it shouldn't be leaking.
May 23, 2017 | Irons
Team international steam iron
Make sure the valve between the base and iron is open.
Nov 23, 2013 | Irons
I am having issues with my steam generator iron. I used it today and after heating up steam was pouring out from the screw on cap. Put on new green rubber ring and I can iron with steam until I sit on base...
I think lime and calcification are the culprit. Use some "CLR" at Home depot, can decalcify the build up on your irons pressure cap.
I have the Rowenta Steam Station. Love it!
Cheers,
Embroidery Services
San Diego, CA
Oct 25, 2017 | Rowenta DG5030 Iron
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
Swan steam iron steam coming out of front and leaking water
the temperature is not set correctly for the fabric.
Sep 17, 2009 | Irons
Water and iron heats up but no steam comes out.
there is most likely a small port where some particles have clogged...fill reservoir with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
May 18, 2007 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
53 people viewed this question
Top Morphy Richards Irons Experts
Mack Baxter
Richard Warren
Richard Warren
Are you a Morphy Richards Iron Expert? Answer questions, earn points and help others
