MAYTAG mvwc3000xw1 WON'T SPIN OR AGITATE - Washing Machines
  • 36 Answers
SOURCE: maytag washer won't agitate
your transmission is no good and needs to be replaced
Posted on Jan 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Posted on Feb 14, 2009
SOURCE: maytag will agitate instead of spin
http://allrepairmanuals.com/maytag-washer.htm?model_number=MAV7901AWW
Please download, the above, service manual, use the troubleshooting procedures, you should be able to locate and repair your problem.
Posted on May 05, 2010
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
tbirdfan1
  • 3051 Answers
SOURCE: washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Sep 29, 2011
Maytag 9700 fills then stops, won't agitate or spin
What is the model number list on the machine? Look on the top of the console.
Oct 13, 2012 | Maytag Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer will spin but won't agitate and it "puts the brakes on" when finished spinning
Hello, Thank You for using FixYa. I will be helping you today.This unit spins in one direction for spin and the other for agitate. If its not agitating and the motor is running then the trans failed. Some of these have a ten year trans and labor warranty. Go to maytag site and put in your model and serial and check the warranty.And the brakes on this unit are pretty quick to stop.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
