I am not able to unmute my soniq tv remote works fine tried all volume buttons one small black box with mute sign appears on top left side of tv
BMW Rider
  • 232 Answers
SOURCE: 32" GE Stereo Monitor Guide+Gem Star Television
Pauz, we need the model number to be able to help you out, located on front of owners manual or on back panel of tv set. some of the GE/RCA built tv`s had problems with extra data bits from the satellite and it would kill the audio, yours may be one of those sets, heres the fix for them, shut off your tv, un-plug the tv`s AC cord from the wall outlet, wait 20 seconds, plug set back in, turn it on and see if audio has returned, you might get lucky :)
Let me know model number if unplugging does not re-set the audio, BMW Rider
Posted on Dec 10, 2007
  • 49 Answers
SOURCE: Proview TFT has got volume option mute , need to unmute it & dont know :(
navigate with the monitor buttons to the OSD (on screen display). menu button brings up the OSD. then use volume buttons to move around. there should be a mute option or indications by symbols how to unmute the sound option. if there is not, i would guess pressing two buttons at the same time might do it.
Posted on Sep 30, 2008
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
  • 253 Answers
SOURCE: Volume buttons and mute/unmute buttons don't work
First open the Control Panel -> Keyboard Layout. Look for the dropdown list for different keyboard models. Scroll to the Dell models and try e.g. the Dell Mulimedia USB Keyboard layout. Stop the GUI with Ctl+Alt+Return, login again and maybe your multimedia buttons will work now.
and for more info contact http://tinyurl.com/m7ghqz
If there is no keyboard layout that fits your needs, you may download the programs keytouch and keytouch editor, which are very helpful creating your own layout.
Posted on Jun 20, 2009
SOURCE: my sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Posted on Aug 05, 2009
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
Apex dt502 digital tv remote was lost
Go to Remotes.com - Or - you can call 1-800- remotes to get a replacement. The new recommended replacement remote sells for $19.95 and has a large red mute button on it. The old one is no longer available unless you wish to do a good web search or try ebay.
Feb 02, 2014 | Car Audio & Video
My iphone is turned on mute how to solwe this problem
If your iphone is on mute, that means that you have slid the button at the top left of your phone down (you can check this by looking at the button and seeing if it is in the down position with a red bar above it). To unmute your iPhone simply slide that button back up. You can then control the volume using either the buttons on the left side of the phone or in the sound settings.
Feb 13, 2013 | Apple iPhone 3GS Black (16 GB)
How do you unmute a toshiba tv
Check your remote control for its infrared emission. If the remote does work for half mute, an other press must make the TV to full mute, and an other press the TV should be unmuted. Check the remote with new batteries.
Jun 18, 2012 | Toshiba REGZA 47HL167 TV
I have a Sony KDF-55WF655. I think the IR sensor is going bad. My remote occasionally stops working for no reason. I have tried numerous different remotes, but I get the same problem no matter which...
Hi:
The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Sep 09, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
Someone turned the sound off on my dell and I don't know how to turn it back on
You have two ways to unmute your speakers.
1. In the right side of your desktop near clock you have an icon like a speaker, right click on it and left click on open volume control. Then go to first box in the left side and uncheck mute, after that your speakers should work normally.
2. Go to start/control panel and double click on sound and devices, it appear a window. In that window uncheck mute from volume tab. That's all.
Jun 07, 2011 | Computers & Internet
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
29 inch RCA Entertainment Series TV I was watching it when picked up remote and it muted the sound and I can't get it to unlock the mute in the menu can anyone help me figure this one out???
Hi try pressing either the mute button again or simply increase the volume to unmute the TV. most TVs respond to this procedure. Pressing the volume buttons on the tv will have the same effect if the remote has failed
Aug 13, 2010 | Televison & Video
Sound wont go on. muted but i have no way of unchecking the mute box
Go to the top of your keyboard. There is a button with a black sideways bell shape icon on it ( a speaker) (the f3 key)...probably four in from the left starting with esc. Toggle that on. It may be on the mute setting now. It should have waves coming out of it when it is unmuted. To the right of that button (two buttons to the right) is the increase volume control button, the (f5) key. Make sure the volume is up! If it is down all the way you will hear nothing and it will be also muted.
I am not sure why if you go into System Preferences (under the Apple icon) and scroll down to Sound and Output, the mute box cannot be unchecked. Perhaps using the function keys to unmute and increase volume on the top of the keyboard will help.
May 07, 2010 | Apple PowerBook G4 Mac Notebook
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
