Question about Seagate Computers & Internet
USB port broke off
My Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) USB port broke off and is now inside the box
JLPicard
  • 14 Answers
SOURCE: Storage and Media - Hard Drive External
Here is a link to Seagate's website Download area. All manuals should be available for download from there: MANUAL
Posted on Nov 17, 2007
Basti
  • 1447 Answers
SOURCE: to boot window xp from usb external hard drive
Use the guide in this link
http://www.ngine.de/index.jsp?pageid=4176
or this forum
http://forums.ngine.de/viewtopic.php?t=1764&sid=a81e27622dda029af42cb532e7cfcd28
pls dnt 4get to rate solution, thanks!!
Posted on Apr 15, 2008
SOURCE: USB port dislodged on 1TB Seagate, how do I open the case?
I did open a Seagate FreeAgent Pro 1TB !
The thing was awful, the case is just a nightmare to crack. The base is easy, you have the screws under the tiny rubber feet. The metal over the electric parts is easy to take apart, you just unglue and carefully open. You unscrew then the four flat-headed screws the hold in place the electrics, and the three big ones that hold together the base and the upper part.
Here comes the nasty part.
You unplug all connectors, but the upper case is VERY (I mean VERY) well tightened. It's held in place in 4 points, and the plastic made my fingers bleed. I can surely say it's a very well made case, strong as military, but impossible to open without destroying.
In the upper part the plastic holding points are quite close to the lower edge, but the two lower ones are somewhat 2,5 or 3 inches away from the edge, and this is where you'll get stuck. I couldn't just pry them open, so in the end, even though the unit is safe and sound, the lid (the part with the Seagate logo) was torn an bent.
My problem was at the electrical part, so I don't care much for the case, but I feel bad for having to literally destroy such a good-looking external enclosure.
Hope this is helpful to all of you in trouble with this issue !
Posted on Dec 29, 2008
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
  • 241 Answers
SOURCE: I connected the external floppy drive to a USB hub
Yes, the external floppy drive must be connected directly to a USB port on the computer instead of to a USB hub.The PC can't see the drive thru the USB hub. Applies to both 32 and 64 bit.
Posted on Sep 07, 2009
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.em?
Sounds like driver problem to me. Re install the driver by using installation disc, or if you have lost your CD, than use this Driver Update Software to update. I hope this helped.
Brian
Oct 24, 2012 | Seagate Expansion 1 TB USB 2.0 Portable...
Claire,
Have you tried connecting the drive to another computer using Windows 7 or later. You could try chkdisk /f at a command prompt or get the testdisk app to identify deeper issues with the drive.
Chappo07
Oct 24, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Install seagate expansion
New drives have to be readied for use. Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. It should be without a drive letter. Right clicking will give you the options of initializing, creating disc partitions, and assigning logical drives. If this seems a little daunting. A wizard should load. If not there is refresh icon on the tool bar. You may want break down the 1TB down to a few partition because of the large size.
Aug 30, 2012 | Seagate 1TB Expansion External Desktop USB...
I have a 1TB seagate expansion external hard drive and i was wondering if i had to plug it in to a power source other than my computers usb port. My teacher has has some really small one and that didn't...
Some do and some do not. if there is no power input jack for DC input then you don't need external power. The 5 volt supply to the USB will power it fine.
Jan 18, 2011 | Computers & Internet
I have a Segate Free Agent Desk 1TB External HDD. Today when I plugged it in the power supply, the LED light keeps on blinking. The Drive is not getting detected by my Laptop. I tried it on my Desktop, But...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 30, 2010 | Seagate FreeAgent Pro 1TB External USB...
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
