Question about Refrigerators
TFX22PRXD GE Fridge Need to install Water Filter
I want to install a water filter for the water dispensed by my GE Profile TFX22PR XD WW fridge
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
nnesmith
  • 162 Answers
SOURCE: GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Posted on Jan 19, 2010
SOURCE: water dispenser in ge profile pfsf6pkx 1.2 year
Have the same model and same exact problem. Did you find any solution? If so, pls post - willing to try anything before the $200 service call. Thanks and good luck on yoiur situation.
Posted on Nov 13, 2010
  • 5 Answers
SOURCE: My hotpoint fridge dispenses ice, but not water.
Set up a shop light, one of those Halogen type lights. And have it shining right on it at the highest setting. The water in the line has frozen. After about 30 minutes to an hour it should start working again. You could also use a blow dryer but I'd rather not stand in front of the fridge that long. Remember if you got kids in the house to warn them not to touch the light!
Posted on Jan 14, 2011
baraquielnar
  • 247 Answers
SOURCE: I have a ge profile fridge TFX28PPDABB. I was not
check the solinoid valve that control water to flow.check busted fuses on pcb baord check water inlet piping
Posted on Jan 25, 2011
GE Profile PSS26SGPA Water Dispenser won't stop dispensing water
water shutoff valve bad or dirty,could be minerals in your water
Nov 23, 2013 | GE Refrigerators
Hi i am looking for a water filter for an aprox 18 year old ge profile tfx22pr model fridge, not too sure what i need. Any help would be appreciated. Thanks, Stan
i believe what your looking for is a water filter you could add to a 18 y.o. refrig?
Check out this link to see what ya need,it could be purchased from any of the places in that link,OR locally from Sear's Lowe's HomeDepot Ace Hardware...just tellthem you dont have a built in filter on your refrig. and that ya need a kit to add one externally. A tip when installing it is to be sure to install it somewhere where you can easily access it when time to replace filter.
Heres that link for the ones available online
http://www.google.com/search?q=refrigerator+water+filter+kits&sourceid=ie7&rls=com.microsoft:en-us:IE-SearchBox&ie=&oe=&rlz=1I7ACAW_enUS360US360#q=refrigerator+water+filter+kits&rls=com.microsoft:en-us:IE-SearchBox&oe=&rlz=1I7ACAW_enUS360US360&um=1&ie=UTF-8&tbo=u&tbm=shop&source=og&sa=N&hl=en&tab=wf&bav=on.2,or.r_gc.r_pw.&fp=41117172812221dd&biw=1093&bih=538
Aug 22, 2011 | Refrigerators
I replaced my GE profile MWF water filter (identical GE part) and now I dont have water dispensing and don't have a working ice maker
Quite frequently carbon fines can be flushed from filter and plug the filter. If you have the bypass plug to replace the filter. Put that in and flush system completely. Take the filter and flush it at the kitchen sink. It is best to fill these with water before installing and flush the carbon fines before installing in fridge.
RJ
Mar 09, 2011 | GE Mwf Ge Refrigerator Smart Water Filter...
I've had a GE Profile side by side (model # GSS25SGPCSS) with in door water and ice dispenser for approx. 6 years. This week the in door water dispenser stopped working. I removed and replaced the filter...
I have the same fridge and the water line freezes up in the door on a regular basis. I have to use a hair dryer and slowly wait for it to melt. It takes about 30 minutes and then works fine for awhile. It has become quite a habit that I'm not thrilled about. Don't waste your money replacing the board or anything else. GE was no help and I'm now shopping for a new fridge bc of this issue. Needless to say that it won't be a GE! Hope this helps.
Oct 09, 2010 | GE Profile Performance 25.2 cu. ft....
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
About 15 yr. ol GE Profile
YOU MIGHT NOT HAVE ONE ge started puting factory filters on in 1999 . you might have an inline one in the water line behind the fridge . but only if the homeowner or installer put one in , ge has nothing to do with it .... replacements at any hardware store
Feb 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
