Question about RIM BlackBerry Bold 9930 Cell Phone
Incufficient network coverage to process your request ERROR Message
My internet was working 2 hours ago then all of a sudden i reciece this error message "Insufficient Network coverage to process your request. Please try again later." SMS seems to be running fine and i have full bars and service (no SOS signal), but everything that uses data ends in this message. been googling this for about 2 hours with only half answered questions, NO DEFINITIVE SOLUTION... PLEASE HELP!! PS: I have done a soft reset with no sucess(pull battery out while phone is on and put back in)did this 3 times. Thanks Alot!
5 Suggested Answers
TanyaAD138
  • 77 Answers
SOURCE: Blackberry curve 8330's blocking mobile network
Sounds like you're in a dead zone. If not then ...
Check in the upper left corner... IF:
1x = you are not connected to any data at all - No emails, text, internet will work send/receive.
1xev= you're connected to data but not blackberry usually the same as above though sometimes you might get lucky and receive only text/pix messages.
1X= Phone calls only. Usually no data (email, text, web, etc)
1XEV = everything is connected and you should be working fine.
If you have 1XEV (upper case and lower case matter ALOT...everything should always be UPPERCASE) and you're still having that problem then go to:
options> advanced options> host routing table
In the host routing table click the button to the left of the roll ball (called the blackberry button) and click on "Register now" and just leave the phone alone for a minute so it can register all your service books again. Then try the web again.
If all else fails pullthe battery and try again ..> Still no good? Call your carrier.
Hope this helps
Posted on Mar 26, 2009
jeevan.m
  • 392 Answers
SOURCE: Wi-fi Problems, Error Message Problems, Network SOS Problems
The most common "cure all" to all devices is the battery pull. Like chicken soup is to the soul, the battery pull can solve many of the problems users encounter, such as application errors, theme problems, data problems and more. Before you do anything else - always do a battery pull.
  • With the device powered on, remove the battery
  • Leave the battery out for about 30 seconds
  • Replace the battery and let the device reboot
This will solve a great deal of problems - always do a battery pull before you seek help elsewhere. You can also perform a soft reset on your device by holding down the ALT+Right SHIFT+DEL keys for about 2 seconds. There is also a double soft reset which some users believe is equivalent to a battery pull. To perform this, do the standard soft reset - the screen will go black. When the screen is no longer black, press the keys again (perform another soft reset). You should then see another
blank screen followed by an hour glass.
Posted on Jun 10, 2009
skdeepak88
  • 232 Answers
SOURCE: I am getting an error message that states,
Switch off GPRS and wireless connection and try again.
Posted on Aug 17, 2009
bahratt
  • 561 Answers
SOURCE: cannot get emails or mms. network states there is
First, it is recommended to download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Posted on Jan 15, 2010
Cannot send out or recieve calls and texts
try turning off off for a min. or two that always help. call your co. and find out if the tranmitters are working they may be working on something in the area you are at. they can tell you if you have fair, good, or great coverage just by telling them the area ( zip coded) you are in. If all else fails like it my case, request a new phone.
Jan 17, 2012 | Cell Phones
My wireless internet works in my hometown, but I go to college 2 hours away and plugged my Ethernet cord in. Everything says its connected, but the internet page will not load. I tried 2 of my friend's...
dont uninstall / reinstall anything on that laptop, will cause more trouble since it was working fine hours ago.
first check your ethernet properties
Aug 30, 2008 | Computers & Internet
I have an airtel sim and it was functioning properly even 2 mins ago and suddenly there is no network coverage and when i had switched on my phone again i get a message sim card registration failed.what to...
Hey no problem jus remove d sim from its socket n den keep it again n den try maximum u ll get it.....i mean ur sim vl b recognized bt coming 2 d matter network der vl b som technical problem........
Oct 05, 2010 | Kitchen Ranges
Network Error (dns_server_failure) Your request could not be processed because an error occurred contacting the DNS server. The DNS server may be temporarily unavailable, or there could be a network...
Its a server network problem your server internet server don't connected to Facebook server. The problem will solve automatically if not solve in 48 hrs contact your internet provider to solve.
Aug 09, 2010 | Facebook Social Network
No network coverage (sony ericsson w995)
did you hit your phone?
try making 'Master Reset' (settings->master reset).if this doesn't work try flashing phone's firmware
Dec 19, 2009 | Sony Ericsson Walkman® W995 Cell Phone
Network connection eroor
In Networks select (only) GSM instead of both. It must be looking for UMTS network first and no finding any it gives the error.
Aug 06, 2009 | Samsung S8300 Ultra Touch platinium-red...
Trouble sending & receiving comcast email messages Motorola q9m
Irecently had comcast email and changed to att email and would lke all my old email imformation changed over to my new one att, how do I go about doing that? I have important imformation that I need to keep. Freddiemumford
Apr 04, 2009 | Motorola Mobility Q9m Smartphone
My n70 suddenly LOST ITS NETWORK OPERATOR
you will need to have the phone firmware reflash
Feb 22, 2009 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry Bold 9930 Cell Phone Logo
32 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
