Question about Yamaha Rx-v565 Receiver
The unit shut itself off
I have a rx-v565 anf if I'm on straight with only the 2 front speakres on, it works fine, but sa I press the stereo button on ther remote it shut itself off. It also shut itself off after a few seconds if the music or the movie button are pressed. I have 5 speakers without a subwoofer
SOURCE: Yamaha RX-V1500 Shuts down after 2 seconds
This set is getting old and is in the Archives section of the Yamaha consumer guide area. But, you can still download the owners manual if you need one. If it is going into protection mode even when there are no speakers connected OR when the sound level is very, very low or zero it is not good news. Yes, unplugging the line cord will cause the protection system to reset itself. But, if it shuts itself off again soon after rebooting it is a sign of bad grease in the output stages -- in all probability. Let me explain: The audio output transistors are mounted to a large heatsink which keeps them cool during operation. They are electrically isolated from touching the heatsink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set). That is the most common cause of your symptoms. However, there are several other possibilities, but I give this explanation a 90% probability based on my experience.
Posted on Jun 17, 2007
SOURCE: Yamaha RX-V595A tuns off automatically
This was happening to mine also, all of a sudden. This solution came from the owners manual. Sure enough, the impedance selector was stuck in the middle , between 4 and 8 ohms....I also, made sure the speaker wires were not touching each other at the splice. Problem fixed.
B
The unit fails to turn on when
STANDBY/ON is pressed, or set in
the standby mode suddenly soon
after the power has been turned on.
The power cord is not plugged in or the
plug is not completely inserted.
The IMPEDANCE SELECTOR switch
on the rear panel is not fully set to the
upper or lower end.
Firmly plug in the power cord.
Set the switch fully to the upper or
lower end when the unit is in the
standby mode.
Posted on Nov 15, 2007
SOURCE: Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Posted on Dec 05, 2007
Midwest-tech
  • 243 Answers
SOURCE: Yamaha RX V800 w/ iTunes Airport Express
thats cause your patch cable is mono get a stereo 3 ring connector.
Posted on Jun 14, 2008
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Posted on Apr 14, 2009
How can I factory reset RX-V2092
Press MASTER ON/OFF on the front panel to
release it outward to the OFF position to turn
off this unit
Press and hold STRAIGHT on the front panel
and then press MASTER ON/OFF inward to
the ON position to turn on this unit.
This unit turns on, and the advanced setup menu
appears in the front panel display.
Rotate the PROGRAM selector on the front
panel to select "PRESET"
Press STRAIGHT on the front panel
repeatedly to select "RESET"
confirm your selection and turn off this unit
Dec 10, 2016 | Yamaha RX-V2092
Yamaha rx-v565 wont turn on. Not "Click Sound" when Press On Button
It sounds like the output ic and or transistors have blown and need replacing. Did you short the speakers or cables?
Dec 01, 2016 | Yamaha Rx-v565 Receiver
I have a yamaha rx-v565 and the hdmi video output is not working correctly. the sound works fine but it just stopped working about 2 weeks ago out of no where
that is the norm for all electrical tech stuff just quits when we need it the most .give it a good thump and see if it helps
Apr 21, 2015 | Yamaha Audio Players & Recorders
I bought Yamaha RX V565 4yrs ago, then after 2 years, may receiver always shut off 5 minutes everytime I open. What is the problem or reason of shutting down my receiver? Thank you
press and hold both the "DIRECT" and "TONE CONTROL" buttons and press power and see what it says on the display. This will give us some idea of what is causing the receiver to turn off.
Mar 30, 2015 | Yamaha Rx-v565 Receiver
We have a Yamaha RX -V565 and after listening to music the entire system shuts down. We turn it back on and it works for a while? We installed new speakers with new 16 gauge speaker wire. Anybody know...
chances are youve got a short at the rear of the receiver. look for frayed speaker wires touching the chassis of the stereo. use a flashlight. it only takes one tiny hair of a wire to short it out
Nov 01, 2009 | Yamaha Rx-v565 Receiver
My Yamaha receiver model rx-v565 audio is putting out choppy sounds when cable is playing. I am using all HDMI connections. My TV is an LG 240 Hertz model and using the comcast HDMI box.
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
Sep 26, 2009 | Yamaha Rx-v565 Receiver
RX-V2600 shuts down
Try checking your speaker impedance. If you have 6 ohm or 8 ohm speakers make sure the impedence matches. On the front panel hold down button that says "straight effect" while pressing Stanby/On button, it will default to SP IMP 8 min, press straight effect again, if you have 6 ohm speakers, then press Standby again to exit setting. Also, double check your speaker wires to make sure they are all connected, and none are loose.
I hope this helps.
Mar 31, 2009 | Yamaha RX-V2600 Receiver
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Feb 21, 2008 | Audio Players & Recorders
Yamaha Rx-v565 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
