Question about Texas Instruments TI-82 Calculator
TI-82 WANT COME ON
HI, I RECENTLY PUT NEW BATTERIES IN MY TI-82 CALCULATOR. WHEN I PUSH THE ON BUTTON , IT WANT DO ANYTHING. IT APPEARS TO BE DEAD. CAN THIS BE FIXED ?
  • Anonymous Feb 04, 2008
    same problem
If you haven't tried this already, adjust the brightness (2nd + Up Arrow). Also, the backup battery, which is removed by unscrewing a small plastic panel in the battery compartment, may need to be replaced as well.
Posted on Jan 10, 2008
It turns out that batteries that checked out as ok on a battery tester were not ok enough.
Posted on Mar 14, 2009
After a few months on not using my calculator, I put in fresh aaa batteries and a fresh 3v button battery. Still will not go on :(
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Aug 29, 2013 | Texas Instruments TI-82 Calculator
Ti 82 just displays a blue screen and charcters are all messed up.
Put new Batteries in, then Hold down the del button for 45 seconds. After that Turn On The Calculator Then push 2nd Down and it should go back to normal
Aug 18, 2012 | Texas Instruments TI-82 Calculator
TI-82:blank screen like a dead battery. Just put in new batteries (all). Not used in years. Won't turn on -- anything I can do?
Hi
The TI82 is a bit old Technology and if you did not use for a few years the screen is dead its a common problem with this model and the TI83
sorry for not been a big help
Oct 21, 2010 | Texas Instruments TI-82 Calculator
I have replaced both the 4 AAA batteries and the cr1620 battery and the TI-82 will still not turn on. What else can I try?
Sep 26, 2010 | Texas Instruments TI-82 Calculator
I have a TI-82 how do you replace the battery.
Push down the tab and lift off the battery cover on the back of the calculator.
To replace the four AAA batteries, simply pull them out and put in new ones, following the polarity indicators. To replace the backup battery, unscrew the cover, pull out the battery, put in the new one, and replace the cover.
Jul 17, 2010 | Texas Instruments Office Equipment &...
I changed all of the batteries and tried to reset the ti-82
Turn it on. Press and RELEASE the 2ND key. Press and hold the DOWN-arrow.
Apr 07, 2009 | Texas Instruments TI-82 Calculator
TI-83 Plus Went Dead
Has it been dropped recently? The screen may have cracked from impact. Press the Reset button on the back using a ball point pen.
Nov 16, 2008 | Texas Instruments TI-84 Plus Silver...
HELP!!
Well, in most calculators, the action of taking out the backup battery practically clears the whole thing. Memory, everything. I myself have a Ti-89 and have not yet experienced this problem, but I have on an older Ti-82 and removed the backup battery and the whole thing is dead now, or at least nothing happens when I turn it on, even after replacing the batteries again. If you still have the manual, I would check out the troubleshooting. If you don't have it, try to find it online. And if you have done both of these things, try getting hold of technical support through Texas Instruments.
Jan 30, 2008 | Texas Instruments TI-89 Calculator
TI-82 Screen Not Working or Black
Try a hard reset. Take out all the batteries, and while putting them back in, hold down the "DEL" key. Then, turn it back on and you can adjust the contrast by pressing the "2nd" key and the down arrow at the same time. I just got this info. online and it finally worked for me...good luck!
Jan 10, 2008 | Texas Instruments TI-82 Calculator
Hi
you should first put it in the form y=mx+b
m-slope
b-y-intercept
x + 2y=4
-x -x 1subtract x from both sides
2y=4-x
/2 /2 2 divide both sides by 2 (to get y alone)
y=2- x/2 now you can put that into your calc. (Y= button)it would like like this on your screen Y1=2-X/2 (X is found under mode)
next hit graph
2nd, TABLE will give you a list of x-values and y-values
hoped i didn't leave anything out and i hope this helped
Sep 27, 2007 | Texas Instruments TI-82 Calculator
Texas Instruments TI-82 Calculator Logo
465 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
