Question about Keurig Vue Brewer V500 Single Cup Home Brewing System Bundle with 32 V
V500 brewer The brewer tries to brew but water does not come out. Tried cleaning brew head without success
SOURCE: One cup brewer, says it is brewing, but the
If the brewer heats the water but it doen not dispense this is probably because air is trapped in the tubing of the water system.
To solve, use as air compresser with minimum pressure (20-25 psi) and force air through the system using an air nozzle that is long enough to reach into the hole into the area where you fill the water. Place your hand under the dispenser and ensure you can feel the air from the compressor coming through.
Once you clean out the lines, you should be good to go.
We have had our coffee maker sitting on our shelf "broken" for months now. We tried this last ditch effort before tossing the machine in the trash and low and behold it worked! :)
Posted on Apr 05, 2009
  • 5 Answers
SOURCE: Brewer pushing water back into reservoir
I had the same problem, contacted Keurig and they suggested the descale procedure, which did not work. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, let sit 2 hours and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since.
Posted on Aug 12, 2009
SOURCE: It says it's brewing - - But It is Not???
If it won't pump water through, how are you going to run a descale? Also this model is supposed to tell you if scaling is an issue. We called Keurig, they said, we will send you a new one.
Posted on Mar 25, 2010
  • 117 Answers
SOURCE: no suction
Run vinegar through it.
Sometimes they have a temp sensor in them which won't allow them to function again until they've cooled off. So try really cold water.
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: My Keurig b40 brewer is not brewing. When I turn
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
llllllllllll;
Posted on Feb 26, 2011
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
!0 Cup home Bunn. Does not brew the number of cups of water coffee (water) in craft. 8 cups of water 6cups of coffee.
If you don't brew often enough you will loose a small amount of water in the tank due to evaporation while the tank heater comes on and goes off to maintain the proper brewing temperature, so if it has been a while since you last brewed, without coffee in brew basket put a carafe of water thru the brewer, you will get less than a full carafe out because it fills the evaporated space in the tank first then uses the rest to brew. Once your tank heater shuts off usually 5 minutes on less you will get out all the volume you put in.
Oct 11, 2014 | Bunn 10 Cup Home Coffee Brewer
I have a Keurig Vue. I have descaled and cleaned the product on schedule but it leaks water from all around the brew head and only 5-6 oz of coffee make it into the mug. I tried to clean out the pin also...
Remove and clean the Brew Head, with the V700 the way to remove would be to open the lid with the handle, place your fingers around the Brew Head, there are tabs to each side, press tabs and pull down and toward you. Wash this out thoroughly in your kitchen sink. Now before replacing the Brew Head, with the handled lid up, turn the back of the brewer so that it is facing you...Look straight down into the top of the brewer, you will see the needles, use an old toothbrush to clean them. Replace the Brew Head and descale the brewer with White Vinegar (do NOT dilute with water) or Keurig descale solution (purchased only through their website). The video to watch the descale instructions is: www.keurig.com/customerservice
Hope this helps!
Oct 28, 2013 | Keurig Vue V700 Brewing System - 110774
Coffee maker will not make but one size cup
If your brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Jul 04, 2011 | Keurig B60 Coffee Maker
Restricted fluid flow
Then try also this tip
http://www.youtube.com/watch?v=DqRs4Ott21s
We have just descaled our Platinum unit and reset all the functions. When attempting to make a cup of coffee, it says it is brewing, but NOTHING is happening. What do we do?
Then try also this helpful tip
Jul 04, 2011 | Keurig Platinum B70 Coffee Maker
After placing bottled water in the container, the unit sounds like it is pumping but no water.
Then try also this useful tip
Jul 03, 2011 | Keurig Platinum B70 Coffee Maker
Saeco Incanto - No water through the coffee brewer
Check the line where the water goes to the brew unit(be careful), disconnect and try to brew coffee, if water exits then the blockage is elsewhere, check the line where it goes into the white plastic valve behind brew unit, if water flows then check the brew unit make sure it is not blocked at the screen.
Jun 09, 2009 | Saeco Incanto Classic Espresso Machine
This is commercial and the water drips instead of flowing,took 20-30 min to make coffee, how can i clean?
Have you tried to brew without coffee to see how long it takes? If yes then use a pair of channel locke to remove sprayhead and then use the deliming sprding that came with your bunn and clean the brew line then try again, if you still get the ame result, the brewer needs to be descaled.
May 06, 2009 | Mr. Coffee Coffee Makers & Espresso...
Keurig Vue Brewer V500 Single Cup Home Brewing System Bundle with 32 V Logo
544 people viewed this question
Top Keurig Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Keurig Craft and Hobby Expert? Answer questions, earn points and help others
