My inverter batery is not getting charged, what i have to do?
    Problem Solver:
  • 21 Answers
Try to check the battery first if it still working.
Posted on Feb 13, 2014
I have solar panels that put out a little more voltage then they are rated at,and they keep faulting out my grid tie inverter.I need a resister to knock down the voltage about 8 volts, got any ideas?
I like to ask, is the voltage from the solar panel messure with some load connected or is open circuit, normally solar panels produce high voltage than the working system, the reasson for that is to have Amperes in of to charge the batery, these is related to the size and power generated by the panel.
No need a resistor or in any case use a voltage regulator to prevent over charge.
Apr 14, 2015 | Inverter Electronics - Others
I have a 2004 Kawasaki zzr 600 that does not keep the charge longer than 2 days. What is causing this problem
hi, you probably have a "almost dead" batery, but in order to properly check, proceed as folows:
1 - give the batery a full charge
2 - disconect both cables (+) and (-) from batery
3 - check charge and see if batery holds it - a good batery must keep 12,7 to 13,2 volts for a very long period
If after this test,considering that batery is ok, then chek your wiring loom for ground losses
good luck
Sep 13, 2011 | 2004 kawasaki ZZR 600
How to charge new battery in my laptop
as i do not know what laptop we are talking about here i asume its not a notebook
if it is the time is slightly lower (6-8 hours)
a normal lap top 10 - 12 hours.
some super batery laptops come with an own (long) guide how to keep the batery alive.
to keep the batery alive a long period of time charge it from 50% not when its at critical.
If u can take out the batery when you are using cable and its fully charged it also has a longer life time. or just take out the cable when its at 100% and recharge it when it gets to 50%
dont have your computer in the lap it can over heat the computer/batery and the lifte time gets even lower.
Aug 24, 2011 | Dell Inspiron B120 Notebook
Inverter continuously charging the batery and battery is getting very hot. How to troublshoot this problem?
remove the battery and take it to auto zone or Interstate battery and have the battery check for a bad cell if you have a shorted cell this will cause the problem. if the battery is low on water this can also cause a problem. if the battery checks out OK and there is no constant draw on the battery from say a water pump then you have a bad converter.
Mar 17, 2010 | Electronics - Others
Inverter seems to be working but batteries aren't
is the bateries draining quikly?, if so try redusing the load on the inverter ,always make sure it is fully charged before use.
Feb 08, 2010 | Xantrex Technology Heart Freedom 25...
Fuse blow as soon as it plug it in
sounds like your inverter has died :)
Jan 21, 2009 | Car Audio & Video
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Problem with getting inverter to work...
Inverters works from 12v carr battery or backup battery, you can not charge the inverter you msay killed your inverter if you connected to 120v wall mount...you use the inverter to give you AC (electric) from 12v battery. if your tv is 12v you need to know how much needed to get the correct connrection as output and input.
Nov 07, 2008 | Vector Maxx SST Power Inverter
Batery problem
I would call the manufacturer. Depending on your battery and what you do on it, that may be all of the time you get out of your battery. I have a small laptop and even on a full charge, I can only get like 2-3 hours of use.
Apr 27, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
