Question about Winter Sports
My 1999 zl 440 runs great at 2500 rpm's or higher but any less than 1500 rpm's I need to lift the choke to bring up the rpm's
    Top Expert:
  • 2,044 Answers
You have a Blockage in your IDLE JET It is STARVING for fuel, at the higher RPM, the High Speed Jet is able to Provide Fuel but not at lower RPM. You make also have a Damaged Needle and / or Seat.
Posted on Feb 12, 2014
I have a 1999 zL 440 it runs fine @ 2500 rpm or higher but if it idles down the only way to clear it out is to lift the choke one notch I already put fresh gas and cleaned the carbs???
Please do not take this the wrong way and I am going to walk you through the process so you can understand and it is actually an easy fix.
ANSWER IS: -
(a) Your Carburetors need to be cleaned,
(b) Jet in your Idle Jet or Low Speed Jet is Too Big
(c) Damaged Needle an/or Seat.
There is 3 orifices that need to be cleaned and requires a wire be fed through the hole on EACH of them. The issue you have obviously is Fuel Related and not understanding what was where when it was started makes it harder.
Completely disassemble the Jets and make sure the Needle and SEATS are in good condition and not damaged, a bad seat will cause it to flood out as you are describing. A TOO BIG JET will do the same thing.
Feb 12, 2014 | Winter Sports
Have a '99 silverado that will not idle
I would check the idle air control valve that is the what controls rpms
Apr 15, 2013 | 1999 Chevrolet Silverado 1500
Idles fast problem
That would be your engine "choke" functioning. It's not a problem. The choke engages when engine is cold and shoots extra fuel to the cylinders to idle the engine up especially in cold with. Once the engine has sufficiently warmed up, the engine will idle back down.
Jun 20, 2012 | 1987 Honda Accord
1995 Kawasaki Ninja 250 will only run with the choke on
you have blocked jets in the carbs,,the carbs need to be removed and cleaned.
Mar 20, 2011 | 1995 kawasaki ZX-9R Ninja
1981 CX 500 B: 1981 Honda CX500 idles at about 2500 rpm. How to ...
under the carbs there is a little black screw turn this by hand anti clockwise until 1-1500 revs if this doesnt work the choke may not be going all the way off or pilot screws under float bowls in recess been adjusted too far screw gently all the way in DO NOT over tighten then unscrew approx 1.5 turns out on both carbs if your experiencing flooding from carbs the bowls need to be removed and the pilot jet attached to the float needs replacing hope this helps steve
May 17, 2010 | 1981 Honda CX 500 B
Pulsar RPM or idling problem.
sounds like when you say cold you mean very cold. If your choke has variable control on it try using more choke until the motor gets warm. Often times the cold weather causes a leaner condition because the air ppm is so much greater leaving you with a leaner running condition.
Dec 06, 2008 | 2007 Bajaj Pulsar 150
1999 DODGE RAM 2500 5.9L DIESEL
if it starts hard he could be sucking air in the fuel system mine did that it was one of the steel return lines that cracked on mine
Sep 19, 2008 | 1999 Dodge Ram 2500 4WD
Winter Sports Logo
285 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
