Question about FreeMotion 750 Interactive Treadmill
Speed varies speed sometimes increases and then slows down
How can I slow down the speed at wich u can walk with the machine it is a propelled mower. Thanks
If the mower motor speed cannot be controlled, then you cannot control the walking speed.
And most transmissions are directly connected to the motor pulley so that if you slow down down the mower's motor, you also slow down the blade speed and cutting power.
Apr 05, 2015 | Garden
My microwave oven siows down and then speeds up.
Is it still heating food properly? You can perform a basic test with a microwave safe mug or plastic cup of water. It should be boiling or too hot to touch within 1 to 2 minutes. Be careful not to overheat the cup if plastic and use extreme caution when touching or removing it from the microwave.
If it is not heating properly then the magnetron may be faulty and unit should be replaced.
Can you tell what specifically is speeding and slowing? Is it the turntable or the humming sound of the unit itself? Many microwaves vary their intensity in order to heat/cook evenly and that will vary the pitch of the sound you hear and sound like it is speeding up or slowing down. If the turntable is slowing and speeding up then there may be a bad motor and the unit should probably be replaced.
If the unit is heating adequately and the turntable speed is uniform then what you may be hearing is simple power cycling and/or fan noise.
Only trained and certified technicians should attempt repair of microwaves due to the hazards of high voltage and microwave radiation leakage if parts are not replaced properly. Although you can have a microwave repaired the cost may be equal to, or higher than, the cost of an equivalent new unit for a 900w microwave.
Feb 28, 2015 | West Bend 0.9-cu. Ft. 900-watt Microwave -...
I have a pronto M61. Forward speed is very slow even when adjusted to higher speeds. Turning speed increases normally. Is there a problem in the joystick?
Has this chair got power raiser for seat? if so check it is fully down or check down micro switch. These will not go fast with the seat raised. A safety option built in.
Oct 16, 2014 | Invacare Pronto M61 with SureStep Rehab...
My 2005 Grand Marquis sounds a little weak when starting up sometimes but when it runs its good until I slow down or when the engine is idle then it shuts off. Doesnt happen all the time but sometimes.
need to increase its idle speed. show it to a mechanic. at first sight it will be ok to increase idle speed of the engine but need to know why it happened.
May 13, 2013 | Cars & Trucks
Beginner sewing leather. Need to slow down machine
Hi lesimpson...
If you need to slow your sewing machine down I would recommend that you purchase a foot controlled rheostat.
You can vary the speed of the machine by pushing down on the foot pedal and it will increase your speed from slow to fast the farther you push down.
I will include a webpage to see one.
Please take time to rate me
http://www.nextag.com/sewing-machine-foot-control/shop-html
Aug 13, 2011 | Garden
The foot control speed slide is erratic it will stop sometimes
The potentiometer that varies the speed is probably dirty. Try spraying some "electrical cleaning solvent" into the pot as you move the control. If this doesn't help, you will probably have to replace the pot if you can find one or replace the speed control.
Good luck.
Jun 30, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Slow Internet Browsing
sir better to contact your ISP provider or internet provider about this. Sometimes heavily load on their connection will slow the speed of the internet. i experienced that myself.
thank you for using fixya
CHARCOIS
Jan 19, 2009 | Dell Optiplex GX60 PC Desktop
I do not know which model of compaq deskpro I have, But I have used a couple ram cards from another compaq... it increased the ram but the video(from youtube for example) freezes... what can I do to fix it...
If you added more ram to the computer that is a slower speed, the memory will run at a lower speed overall. Even if one stick is faster, they will run at the speed of the slower memory. I would check that. Sometimes it slows your computer down to increase the ram if you decrease the speed.
If its the same speed, you can usually increase your video dedicated memory in the BIOS settings.
Good Luck!
Dec 09, 2008 | Compaq Deskpro EP 6450+ Model 10000 PC...
FreeMotion 750 Interactive Treadmill Logo
16 people viewed this question
Top FreeMotion Exercise & Fitness Experts
ray gallant
Electro Med Services...
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
