Ticking noise hard drive is ticking like a clock
5 Suggested Answers
  • 5 Answers
SOURCE: Ticking noise
search google and type why is my refrigerator clicking,most sights say the start relay switch has gone bad.mines doing the same thing,if so its a 30$ fix
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=676782&PPStack=1
Posted on Dec 12, 2007
SOURCE: Western digital 500gb external hard drive ticking noise- Help !!!
There is a number of data recovery solutions online. Just google it. I would recommend one that sends out a static sensitive bag for transportation. But the customer service rep you spoke with, is probably right. The actuator arm has probably locked up and is failing to move back and forth reading and writing to the platters. Good luck and i feel for you with it being your new born on the hard drive.
Posted on Mar 10, 2009
SOURCE: Help!! Western digital 500gb external hard drive ticking noise
Yes. This is going to sound strange. Put the drive in a plastic bag and put it in the freezer. Next day, take it out, hook it up, and see if it is recognized.
If so, under My computer, right click on the drive - click Properties - then Tools, then Error Checking. Check box Automatically Fix File System Errors. Let it run. If everything shows up, be ready to transfer wnat you want off of it.
Freezing shrinks the metal parts . Microscopically, but often enough to get stuck parts free enough to get working.
I just went through this with a 750Gig Book. now i have reformatted the drive (after transferring all over to new drive) and the clicking is gone and all disk checks are fine and i wonder whether to trust this device ever again... Hate to just throw out a large drive.
Posted on Apr 05, 2009
  • 1288 Answers
SOURCE: When i go to turn
Assuming there is no CD in the drive, the ticking sound you describe sounds like hard drive activity, or at least a hard drive that is trying to actuate. Did you or someone else drop the laptop? This is normally a result of the reading heads being out of alignment with the disc platters, a damaged bearing, or a power isssue to the drive that is preventing the reading heads reading the disc platters.
Either way, it is normally a harbinger of death as far at the hard drive is concerned, you will most likely need to replace the drive.
SOMETIMES, you can get the hard drive working one last time to pull any data off you need, this can be done by (assuming it is a SATA drive) connecting it to a spare SATA port on another computer and getting the data copied off. One extreme measure is to place the drive in a sealed bag to prevent condensation and stick it in the freezer for a day, before connecting it to the computer.. I used to laugh at this but it does work.. causes the disc platters to contract and gives enough time to recover data before it warms up again
Posted on Dec 31, 2010
Haier dryer ticking noises
ticking you hear is the timer motor,drive motor is most likley geeting too hot.check vent ,dryer pushed back too far?hose kinked ?stopped up?too long?vent should be short,straight and of hard pipe.clean vent twice a year,heating element will love you.you will not love to replace it.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
My hard disk turn off every 1 hour then it make a unusal sound nd wont restart again . Then again next day its start and after 1 hour it gets hang nd start making tick tick noise ... does m hard disk...
Go to the power settings and set it to never turn off hard drive...the tick tick noise are the read and write heads working (that's what writes information on the hard drive) which is perfectly normal with an older hard drive....the hang is probably a virus or needs a good cleaning...I recommend advanced system care as a program to clean your hard drive and fix the errors....uninstall any and all programs not needed or unused
Sep 15, 2011 | Computers & Internet
I was using my buffalo 500gb harddisk but then it just got lost on my screen, i couldnt see it anymore. checking it, it was making a certain sound like a clock ticking, how can i repair it?
> making a certain clock-ticking
That's a definite sign that the disk-drive has "died".
If the warranty is still valid, exercise the warranty to get it repaired/replaced.
Nov 01, 2010 | Buffalo Technology Computers & Internet
I own a SimpleTech external hard drive (250 GB). When I would turn on the hard drive, I could hear it power up and a fan like noise come from it. When I tried turning it on today, it is only making a quiet...
a dirty hard drive the reader arm is skipping across platters on your hard drive being external im not sure on an internal hard drive then give it a firm tap on one side to free it up remove all the dust from the hard drive then replace all the leads that are attached to your hard drive
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 08, 2010 | Computers & Internet
Won't work, ticking noise.
Very likely no. Usually a hard drive that clicks is good for no more then a paper weight. There are expensive solutions out there. Companies that can retrieve data from defective drives. You would only use this solution for VERY important data recovery as the process is time consuming and extremely costly.
Mar 15, 2010 | Western Digital Passport 320GB External...
Acer aspire 5315. now light no nothing will ocasionaly get lights and power up sometimes for a few secs other times for n hour or so.... checked hdd/cdrom/mem/powersupply voltage etc... all are ok... get...
hey Mike,
first off, if its in warranty, contact acer. their support is excellent.
usually a ticking sound from a laptop is indeed the hard drive (not much else to make a ticking noise other than the fan). If it makes the ticking noise when powered off and ac plugged in, then yes, likely mainboard. Pull the battery and see if this helps (battery or charging circuit may be a problem). Also, Remove the hard drive temporarily, as it draws a fair bit of power, and see if you can boot successfully to a live cd (Gos or Ubuntu are good). If a live cd runs okay, then it may in fact be the hard drive.
If all else fails, Acer mainboards are VERY reasonably priced. It may be worthwhile to swap the board. Let me know if this helps or not :)
Aug 09, 2009 | Acer Aspire 5315 Notebook
Mar 10, 2009 | Western Digital My Book Essential 500GB...
Mar 10, 2009 | Western Digital External USB 2.0 80 GB...
Problem 2
The feint ticking noise usually indicates a dead hard drive.
The heads are flicking back and forth at random and make the ticking noise you hear.
The drive can still be detected because the physical hard drive and the controller board on it are in reality 2 seperate components working together. So the controller board is also trying to access the hard drive without luck.
If you have not dropped the unit or knocked it over etc, then chances are the controller board is what has died and therfore you still cannot access the drive. You may get lucky in finding a new controller board to replace a failed one and that will also get your data back.
May 14, 2008 | Acomdata 250GB External Firewire HD 250 GB...
Hard disk
Generally a ticking sound indicates a faulty hard drive. If you can access your data, i suggest you back up your data as soon as possible.
there are several possibilities that cause the ticking such as:
1.) The clicking sound appears to only occur when the drive is idle. Forcing the drive to be busy silences the ticking while the drive is busy.
2.) repeated attempts to spin up the platters
3.) The ticking sound comes from the hard drive is caused by repeated attempts to find track 0.
if your noise occurs from solution 1, then I would'nt worry about the noise. However if its caused by problem 2 or 3, then I would backup data and purchase a new drive.
Hope this helps!
Brad Nelson
Mar 15, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
