Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
Scotsman cm3 does not harvest
When you press harvest button it will harvest but does not automatically harvest
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
First i need the model number CM3 is a controller number and is it a blue or black controller. then i will be able to help you.
Posted on Sep 06, 2016
  • 202 Answers
SOURCE: ice sheets too thick to shatter when dropped
timer not working properly replace if necessary
Posted on Jul 24, 2009
SOURCE: hi.my scotsman mv 450 ice machine harvest cycle is
ir_ah77@yahoo.com
Posted on Feb 22, 2010
  • 112 Answers
SOURCE: Scotsman cme 506ae-1a harvest to soon. Where is
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Posted on Dec 11, 2010
TheMobilian
  • 8220 Answers
SOURCE: does the scotsman cm3 ice
Scotsman service manuals
Posted on Jan 16, 2011
  • 1043 Answers
SOURCE: scotsman icemachine cm506 stuck in
check for power to valve coil. If it remains it's a control problem. If no power and still in harvest, valve is stuck. Unit usually does not exceed a 6 to 8 minute harvest.
Posted on Jan 21, 2011
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
How to get ice going
First is the machine making ice ? If it is making ice is it thick enough so the water comes in contact with the ice thickness probe. This has to happen so the machine will know it needs to go into a harvest. You should not have to fores it into a harvest it should be doing it on it on. There is a harvest button on the CM3 controller but when you push it its going into a harvest and when it finishes the harvest it will shut the machine OFF. I really need more info. What is it doing or not doing?
Mar 19, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman CM3 does not harvest and does not refill
Remove the ice thickness probe that is hanging at the top of the evaporator plate and clean really good put it back push the freeze tab. If the ice is still getting to thick and not causing the machine to go into a harvest then replace the probe , make sure when you do this to set the thickness by using a 1/8 inch drill bit, lay the bit flat between the evaporator plate and the probe turn the 1/4 screw in or out to achieve the 1/8 inch. The probe is what sets the machine into a harvest, if the ice is not building up enough to cause the water to come into contact whit the probe long enough then it will not go into a harvest. if the ice is getting to thick and the water should be running over the probe it should have went into a harvest if not then the probe is not sensing it to tell the CM3 to go into a harvest.
Feb 11, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
your sump level control sensor is not reading the water level drop to go in harvest.you can do a self check test or replace the sensor(little blk box) could be wire harness. check to makeure your water value is leaking through
After the freeze mode finishes the machine stops and the refigeration light stays solid and will not havest unless i press the harvest button
The sump level control senor is not reading check it for rust or corrsion same thing with the harness lso make sure there is no scale build up on the float stem
Feb 05, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Water keeps running on cm3
Replace the ice thickness sensor hanging on the front of the evaporator plate. when you turn the power off and back on factory default is to go to harvest first. if the ice thickness sensor dose not sense the ice is thick enough then it will not go into a harvest. before you replace the sensor take it loose from the evap plate and drop it into the water sump tray if it goes into a harvest then replace the board. if not then replace the sensor.
Nov 23, 2013 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman cme1356 stays in harvest too long
First make sure the machine is clean and sanitized. Also make sure the harvest assist plunger is engaging. Is the hot gas valve opening up? is the pump running water over evap plate.
Aug 09, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman cme 506ae-1a harvest to soon. Where is the adjustment timer the harvest is also too long?
Jul 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Kitchen Appliances - Others Logo
302 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
