Question about Audio Technica ATH-ANC7B Headphones
ATH-ANC7B Right headphone does not work...no sound come through and no noise-cancellation on that headphone. The blue LED on the left headphone works (and does sound and noise-cancellation on that headphone) so it is definitely getting power from the AAA battery in the right headphone.
2 Suggested Answers
  • 11800 Answers
SOURCE: I have the audio-technica Quiet
Each headphone is comprised of 2 parts: the shell (that houses the jack and the swivel post and the plate - to which the comfort pads are attached and on which the speaker is fixed. In this model the plate is glued to the shell so if you want to open it you will have to force it open - put a knife between the outer shell and the comfort layer covering the plate and slowly and methodically pry it open.
Posted on Nov 17, 2010
Left Ear cup not working.
Either ship them back to manufacturer if still under waranty or you'll have to re-solder the wiring to that speaker if they have become disconnected or yanked accidentally of which the leftside is usually where the headphone cable first enters in the left side.
Oct 10, 2013 | Audio Technica ATH-ANC27 Headphones
I have an audio technica ath-anc7b noise canceling headphone. There is a crackling sound when I tap lightly on the left hand side of the earphone. There may be something loose. How can I open the cas
I was researching a similar answer and discovered that the left side ear piece actually is actually held together with 3 torx screws that are visible upon removing the ear pad and the padding surrounding the driver. I haven't had a chance to attempt a fix yet but remove those screws and see if you can open the ear piece.
Oct 06, 2012 | Audio Technica ATH-ANC7B Headphones
Sound is only coming out of one side.
check speaker wires connected to amplifier try to swap it between right and left speaker do the same to audio input jack (usually RCA jack). If it still works one channel only, probably the problem is in the power amplifier
Apr 03, 2011 | Audio Technica ATH-M30 Professional...
There is constant static in the left ear when the noise cancelling is turned on. The only way to solve this is to turn the noise cancelling feature off. Is there another solution?
these things are suppost to have a little static noise when on. next time get noise reduction headphones. they are like headphone style ear protection like what construction workers use. but only more stylish and they contain speakers. and no killing batteries for good sound. they are regular headphones but with really good sound isolation
Oct 25, 2010 | JVC HA-NC250 Headphones
My left ear headset does not work. the right one is fine and the battery is charged,
sounds as if you have a short in the left ear. solution would be to send in to manufacture. Or return to the store.
Oct 04, 2010 | Bose QuietComfort 3 Acoustic Noise...
Lost sound in the right ear of my audio technica ath-d40fs
The most common problem with earphones are the wires. Usually near the end. You can carefully open the headset to expose the wire connection, and check for continuity.
Nov 28, 2009 | Audio Technica Audio-Technica ATH-D40fs...
If I jiggle the cord in the stereo outliet, the sound switches from left to right earpiece and has to be just right in the outlet to get both earpieces working at the same time.
If you plug the headphones into another device do they stay on solid?
The problem can be the cord/plug (headphones) or the socket which your plugging into. Socket might need re-soldered or replaced.
Jul 26, 2009 | Bose QuietComfort 3 Acoustic Noise...
Bose Headphones only works on left side.
Have same problem. Play with the plug in the socket. I'll bet it you can occasionally get both working. Not a solution since it probably won't stay working. I have an old plug and it fails too. I'm afraid they did't make their plugs to the right tolerances. Used to work once. Annoying for this expensive a headphone.
Mar 29, 2009 | Audio Players & Recorders
Audio Technica ATH-ANC7B Headphones Logo
52 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
