Question about Sony VAIO Laptop FL Inverter 1-443-890-11 VGN-AR VGN-FE VGN-FZ
Sony vgn lcd inverter pinout
Need pinout for input connector (6 pin)
4 Suggested Answers
  • 149 Answers
SOURCE: I need a high level input connector for a Sony Car Amplifier
best buy-wal mart-circuit city-ultimate electronics-radio shack- any stereo shop that deals with car audio-hope that helps look to spend between 12 and 35 dollars
Posted on Jun 19, 2009
budmrtn
  • 11361 Answers
SOURCE: the screen is white >>>
Your inverter board is OK otherwise you will not get any light on the screen, there is only one inverter board, Check the flat ribbon cable connected to the LCD panel (locate behind the LCD panel), when this connector comes off you will get white screen.
Posted on Nov 06, 2009
maxcarson
  • 7627 Answers
SOURCE: Sony Vaio vgn-fe590p, when starting up the screen lights up, but it is dim and blurry. Could this be the inverter, or the lcd screen is bad?
Start with drivers,http://esupport.sony.com/US/p/model-home.pl?mdl=VGNFE590P&template_id=1&region_id=1&tab=download#/downloadTab . Has it been damaged? Dropped, jarred, etc. It may be the monitor/graphics is going. Hard to say exactly. Is it overheating?
Posted on Dec 03, 2012
I have a Samsung 46 LN46C630K1F CCFL TV with a backlight that doesn't come on. How can I tell whether it is the inverter board or the power supply board that is bad?
Check and replace the damaged components at its back light inverter circuit. What else to look for? If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/ Sometimes the back light inverter board might need replacement.
Feb 20, 2017 | Samsung Televison & Video
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
The screen is white >>>
Nov 06, 2009 | Sony VAIO VGN-CR510E/T 14.1" Laptop
Need input connector (13 pin din?) pinout.
Call Bose. Do google search. They sell accessories on line. They are vry helpful.
Apr 24, 2009 | Audio Players & Recorders
LCD the same on the Sony vaio vgn SZ 650N and the 660N?
Not good! Each laptop LCD screen has it's own backlight inverter. The cable of wires coming from the inverter, has a connector, or two connectors. They must match up to the one/s on the LCD screen.
A person would think, "Well. I'll just buy the inverter that matches this LCD screen then. They're relatively cheap!"
Doesn't work that way. The inverter cable/s must match the connector/s coming out of the laptop.
What to do? Remove the LCD screen bezel, and remove the flat strip of plastic, in front of the keyboard, (Below the LCD screen), and find out.
No? Doesn't match up? Sell that LCD screen on Ebay. Recover some of your money or all.
Buy the right LCD screen.
In the meantime, should their be documents, or whatever that you need to access, you can plug an external monitor in.
Would appreciate it if you would rate this solution.
Apr 17, 2009 | Sony Vaio VGN-SZ660N/C Notebook
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Aug 22, 2006 | Audiovox BA200 Car Subwoofer
Sony VAIO Laptop FL Inverter 1-443-890-11 VGN-AR VGN-FE VGN-FZ Logo
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
