Question about Avanti FFBM920W
How to replace Avanti FFBM920w defrost control board
E4 error message
The E4 error code is a result of a malfunctioning defrost sensor. If the error code is on the right then it is the defrost sensor in the upper chamber.
Attached is a link to Avanti service and parts. Provide them with the model number of your wine cellar and they will be able to provide you with a price and information on the part needed for repair.
http://www.avantiproducts.com/index.php?page=contact
If you have the owner's manual or are able to speak with a service technician through Avanti, then this can be a diy repair.
Sep 06, 2013 | Avanti WCR5450DZ
Wont work AT380 AVANTI tred mill - comes up EJJ SOMETHING OR OTHER PUSH BUTTONS DONT WORK
ADJUST THE REED SWITCH ACCORDING WITH DIAGRAM.
NOW TIGH THE FLEXIBLE CORD FROM KEYPANEL VS DISPLAY BOARD AND THEN CONNECTOR FROM DISPLAY BOARD VS LOWER BOARD OR MAIN CONTROLLER BOARD.
11_30_2011_12_40_41_am.gifIf you can open the keypanel and clean with contact cleaner will be a good idea with carefully and patience. sincerely.
Finally if the problem persist you will 2 options: a) faulty display board and 2) Main controller board.
E.CUADRA
MANAGUA, NICARAGUA
Aug 21, 2011 | Avanti Fitness AT380 Treadmill
When turned on right hand display comes up with 51 then flashes with the number 68. Dead man button works but not any of the controls. Alex
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 11_30_2011_12_46_08_am.gif
Try to tight the keypanel flexible cable vs Display Board and then tight the connector from display board vs Main controller board(lower board) and will be a good idea spray with contact cleaner the keypanel with carefully and patience.
Finally you will have 2 options if the problem persist: 1) display board faulty or 2) main controller board faulty. See. the block diagram how the main controller board has 90% of function in any treadmills.
Jul 14, 2011 | Avanti Fitness AT380 Treadmill
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
I have a Avanti wc492d wine cooler that is not working. The unit shows power(lights are working) but it will not cool at all. I can here a click sound when I change the temp set, but the cooler will not...
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti WC492D Wine Cooler
What can i do if my fridge is not cooling?
Hello and Welcome to FixYa!
Refrigerator mal function can be due to several reasons...To trouble shoot poor/no cooling problem, you need to carefully check all the below quoted possibilities one by one:
  • Start Relay (Compressor Clicking won't Start in case of faulty).
  • Bad/dirty Condenser.
  • Defrost timer Settings.
  • Cold Control Settings.
  • Defrost (Ice built up on the evaporator coils that chokes the air flow to the freezer/refrigeraot compartment).
  • Evaporator Fan.
  • Main Control Board mal function.
You need to cross check all above quoted possibilities one by one to locate/trouble shoot the problem.
Best of Luck,
Your token of appreciation in form rating will be highly obliged.
Concerned.
Sep 18, 2010 | Avanti Refrigerators
My Avanti refrigerator model #ff110 120 the freezer is 30 degress and refrid. is 60 degrees I have defrosted and unplugged for 24 hrs and still have same problem please help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Avanti FF1101W Top Freezer Refrigerator
My Avanti refrigerator (about 12 cubic feet) is freezing everything in the refrigerator section.
heatman101
Sep 07, 2010 | Avanti 248Y Compact Refrigerator
Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
Jun 17, 2009 | Avanti EC15W-2 Compact Refrigerator
AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Jun 04, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Avanti FFBM920W Logo
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
