Question about Samsung Computers & Internet
Samsung monitor 204b screen image is split in to two parts; the upper part OK but lower part is gibberish, ghosty?
The monitor shows split image, upper part looks OK, but the lower part is gibberish, streaking, funny meaningless images. But screen is stable. No power supply problem. It is bright.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
Interference. Separate the wiring so it doesn't touch. Touching wires create cross-talk of signals and keeps from running normal.
Posted on Jun 22, 2014
  • 152 Answers
SOURCE: Samsung 931B Monitor Screen will not stay
jane657, Hi there. Will you stop pushing the On/Off button on your lcd/fpd. It's Broke. Period. End. Finito!!! You will not fix it. However there is one test that you should do to determine hoe bad the problem is. You will need to reconnect the 931B to a known good pc that has been fully booted and has the WIN-DESKTOP or IE fixya web page showing. quickly connect the931B to the wall outlet and the PC. Turn on the monitor!!! Yes, I know it will only come on for a second..After the screen goes to BLACK, Shine a bright flashlight onto the screen at different angles, 1-2 inches from the screen. Let me know if you see something even though the screen is black. Anyway here are your options as a consumer/user. 1. Check if unit is under warranty. 2. Check withh Samsung to see if they have a SWAPOUT program. You send them your monitor+$40-$90 and they return a refurbished same model to you with a 30 day warranty. 3. Trade in for new monitor. 4. Check with local TV/Monitor repair guy who knows all there is to know about cold-cathode-fluorescent-tubes, their power-source(inverter type) and lcd monitor power supplys (SMPS) 5. Repair on your own. Not recommended for amatures with no solid state troubleshooting skills and no instrumentation for support. Bye for now. I'm louie12fix on fixya or lmistyrel@ aim.com
Posted on May 14, 2009
SOURCE: Samsung monitor has "streaks"
LaurieEm posted a solution which seems to work for me (in addition to some other stuff, read my problem description) for this here http://www.fixya.com/users/laurieem
Try re-plugging your LCD monitor's VGA connection. It may be a case of corrosion on the pins or bad puggin of the cable. The problem is also reduced by using compressed air to blow out the cicuitry in the back of the monitor to remove dust. Both of these seem to work, and if you can't solve the problem totally with one, try the other one as well.
Posted on Jun 07, 2009
xptareq2000
  • 1447 Answers
SOURCE: When turning on the monitor it shows the image for
it is problem memory ic go to authorised service centre
Posted on Sep 03, 2009
Testimonial: "Thank you for the advise. F. Martin"
  • 152 Answers
SOURCE: Screen flashes - samsung 215tw LCD monitor
walkstex, I will answer the last ? first. All LCD monitors WILL NEED to have their "cold-cathode-fluorescent-tubes" replaced!!! As long as your display had a Bright, Crisp image displayed on it before this "FLASHING" symptom occured, then you don't need new CCF tubes. Your problem seems to be occuring in the electronic ballast circuit called an INVERTER. It Takes 12-15v DC and turns it into 800-1200v ac to light up the CCF tubes. This is the same technology used in the new style curlieQ screw-in light bulbs called CFL's. Only difference is they use what is known as a CONVERTER circuit----AC to AC!!!! And the tubes hung horizontally on the rear of your LCD panel are thin and straight. So, to answer your first ? Yes, it is an issue of getting the CCF tubes to light up. (backlighting) Now, I should also mention that there could possibly be a problem with the main power supply in the monitor. It is called a "switch-mode-power-supply" (smps) that supplies DC for the digital signal processing board (typ +5v) and 12-15v for the inverter. Well, This typical type of symptom could be as simple as a thermally fractured solder joint on the power supply board or some bad Filter capacitors could also need replacing. I suggest that you search web to find out more about the things I have mentioned in the above text. Do search for things like "swollen capacitors", "Bulging Capacitors" and checkout www.badcaps.net for some pictures of typical failures. Get back to me if you want to carry this any further on your own. Bye for now. I'm louie12fix on fixya or lmistyrel @aol.com
Posted on Sep 23, 2009
  • 732 Answers
SOURCE: I have a Samsung SyncMaster 931c monitor (2.5 yrs
jcacolice, Most likely your 931c will need work done on it. When strange things start to occur with any LCD CCFL backlit display I would suspect the "switch-mode-power-supply" first thing!!! If unit is out of warranty you or someone will need to inspect and troubleshoot it. A good place to start will be to see some DIY videos on YOUTUBE. Try search of "lcd monitor disassembly" and "lcd monitor repair" and learn all you can about the TOP CAUSES of monitor failure. Then visit (FYI) www.ccl-la.com/badcaps.htm and www.badcaps.net for more info. Explore ALL your options before you do anything. Then get back to us here at fixya if you still need some asssistance. Read some of my other responses in my fixya profile and other those of other tech's on fixya.
Hope to see you back on fixya with a plan of action!! 12fixlouie
Posted on Dec 24, 2009
ONLY BLINKING POWER BUTTON ON THE DMONITOR. NOTHING ELSE IS THERE.
This is a common problem with the Samsung 204B units that have been in service for a few years. Parts called capacitors in the power supply start failing and causing the board to not start correctly. The blinking power button is just the power supply restarting over and over. The monitor is easily repairable, you just need to replace the 5 capacitors that have failed. Here is a link to a page that shows how to open the monitor, get to the power supply board and what to replace.
http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 17, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
When I attempt to bring it back up, or turn it on,monitor screen stays black long time, then flickers, then slowly, ever so slowly, comes into view. Works ok at that point. Happening every time now, and...
The Samsung 204B monitor have a know issue with failing power supplies that cause the exact problem you are having. At first they are a little slow to display a picture and the more you keep using it the longer it takes for the display to come on. The repair is simple if you can solder. Here is a link to a site with additional information on this repair. http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ This Samsung 204B monitor is a great unit with a simple to solve issue. No need to trash a good unit.
I hope this helps, if so please rate our solution.
BuddyMc
Jul 04, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
SyncMaster 204B screen appears in 5 min after turning monitor on. First 7-10min screen is dark and slowly increases brightness. The picture becomes normal in 15-20 min and all is OK until the monitor is...
How long have you had the monitor. It sounds like a defective backlight. Usually when the circuit driver for the backlight starts to go bad, the monitor will blink. If this is the case, eventually the monitor will not turn on at all.
Jan 12, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
I am having a old Samsung SAMTRON 55V (15") MONITOR. Now I isnstalled a logitech web cam. The image is not showing properly. Ghosty picture. Pl. help.
look dear ,,your monitor is not compatible to the video output of your web cam,,,,so you have either have to replace the monitor or your web cam...but problem is that if monitor is very aged then you won't get cam compatible with it...
Oct 21, 2010 | SAMTRON 55V 15" CRT Monitor
Samsung 204B has a *very* long response time, b-w approx 10sec
I looked at the picture, well you have me stumped. Caps look OK. CapS on Logic board look OK.
Apr 12, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Only getting 1/2 screen upper half black
Try connecting the monitor to a different computer.
If you get the same symptoms, take the monitor to a qualified technician -- they probably will charge your $25, and then tell you that the electronics inside the LCD are damaged, and that you'll need to replace the monitor. Instead, exercise the "warranty" on the monitor, to get it replaced, or "invest" the $25 "inspection-fee" as part-payment of a new monitor.
Jan 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
I have a 204b moniter that the lower half of the screen faded to black then shows two half screens that are filled with so many vert lines that you can't see whats on the screen.
the screen is toast. if its black and not showing whats suppose to be on the other half.if you tried restarting the computer and unplugging the monitor and it is still happening then there is nothing to do. monitors are not built to last long, the cheap ones. it is good to get one with a good warranty because the pixels go out.
Sep 29, 2009 | Samsung Computers & Internet
Samsung SyncMaster 204B The blue power button is on but the screen is black. When I turn it off and back on it shows the screen for a second then goes black. Can you please help me. Thanks
Got the same problem, happened yesterday for me, Did some research and it looks like its bad capacitors in the back, check out this page for more information... i'm taking mine to an electrician to fix today... luckily he's related and should be able to fix it on the cheap...
http://pavel.kirkovsky.com/blog/2009/03/samsung-syncmaster-204b-repair/
Apr 02, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Connecting a Compaq nx6310 laptop to a bigger monitor
Should be Function Key and F4 (or a similar FKEY will show a monitor screen)
Press 1x to push image to ext. monitor
Press 2x to have dual display
Push 3x to just have laptop screen
Dec 08, 2008 | HP Compaq WF1907 Monitor
Computers & Internet Logo
55 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
