Question about JVC PC-XC60 Shelf System
Cannot play radio - red light says standby - JVC PC-XC60 Shelf System
KR-V6050 I cannot get audio to work on radio, video or any other setting. Also the red standby light stays on all the time, even when the power switch is turned off. Alan
Check the input / output connections are in the correct places. The red standby will stay on when the unit is off showing that it is ready for use. To confirm, turn the power off at the wall. The red light should go out after a few seconds.
Nov 20, 2016 | Kenwood Kr-v6050 Audio Video Stereo...
How do you turn off standby on a kenwood krx-89 stereo
Hi, is the red light that says power On? If not, it could just be the fuse since I had the same problem. If you take the lid off, it should be in the left rear and is a 250v 6amp fuse. I had the same problem where only the standby light and the input lights were on. Neither the radio and cassette lights were on.
Dec 20, 2012 | Kenwood Audio Players & Recorders
Power switch
The red standby light is always on. It should only change when you press 'power'. When you turn it off, it is on 'standby', meaning you can switch the switch to make it start-up in play or record mode by using a timer and the switch below the power switch. This is normal for Sony.
Feb 24, 2012 | Sony MDS-JE330 Mini Disc Player
My power light turns yellow instead of red i have to hold thepower botten to make it red
With the Wii system, when you hit the power button, it goes into Standby mode. That is the yellow light. In standby mode, the system draws a little bit of power, and it will go into a ready to play state faster than when Off. Holding the power button FULLY powers off the Wii system, and that will give you the red light. Hope this helps!
Feb 27, 2011 | Video Game Consoles & Games
I have a gpx hm3817dtblk shelf system and i was wondering if you can get the alarm to play a cd instead of the radio or if you can do either one and how? Or does it even have an alarm?
The manual:
http://www.retrevo.com/support/GPX-HM3817DT-manual/id/1183ag710/t/2/
Page 6>>>>
Setting the Clock
a. Press the STANDBY button until the unit is in standby mode.
When the unit is in standby mode, the STANDBY button will be red.
b. Press the CLK ADJ. button. The time will begin to blink.
c. Press the HOUR and MINUTE buttons to adjust the hour and minute.
d. Press the CLK ADJ. button to set the adjusted time.
Setting the Alarm
b. Press the ALARM SET button. The time will begin to blink.
c. Press the FUNCTION button to seleect CD, Radio, AUX, or Buzzer.
For Buzzer mode, the display will not show any indication.
d. Press the HOUR and MINUTE buttons to adjust the hour and minute.
e. Press the ALARM SET button to set the adjusted alarm time.
An alarm clock icon will appear on the LCD Display when the alarm is set.
Jan 03, 2011 | GPX HM3817DTBLK Shelf System
Unit does not turn on or display time
do you mean a power surge, if so the surge may have overloaded the elctronics,=cooked ,so afraid is u/s
Jul 07, 2010 | Fisher SLIM-3010 Shelf System
DRC277a red light only
The red light on my player is on when the unit is off and it is on when in the standby or play mode.
Jan 14, 2009 | RCA DRC277 DVD Player
Message that game will not play at current video setting
Hello.
You just need to restore the defaults for the video. Here is how to do this.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
I hope this helps!! Good luck!!
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
JVC PC-XC60 Shelf System Logo
32 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
