B210 Photosmart Plus has HPcoloured cartridges in but is now not printing successfully. Background colour is lavender
Printer is producing a lavender background although skin colours look natural. I have had an on going problem with my printer recently and the problem of it not printing 'at all' in fact I was getting blank sheets! has now been solved when I put a new black cartridge in. However the colour is not working. I was also having this problem just before the black problem occured and that was major! I therefore ignored the colour irritation and gor the black sorted. I am also using HP coloured cartridges as well as HP black cartridges. My Ref. No for my previous complaint is 3001058292. Please can you help This printer is not a year old.
    Habit-Forming:
    New Friend:
  • 64 Answers
Hey, i'm going to mentioned some steps here, follow these as it is:
1. Use Genuine Ink Cartridges
2. Cross Check Estimated Ink Levels
3. Replace All Low or Empty HP Ink Cartridges
4. Check for all Ink Cartridges are properly vented and seated correctly
5. Clean the print-head
Now Start your HP Printer again, i hope, i works fine, to know more, dial my toll-free number +1 (833) 493-0111, Regards
Posted on Apr 08, 2017
SOURCE: Lexmark 3200 colour printer
Dear friend There may be serious problem in the printers mother board which is not sending any signals for the bklack cartridge and should be diagnosed. Pran
Posted on Jan 24, 2007
khanmohammad
  • 188 Answers
SOURCE: hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
Posted on Mar 25, 2008
Mrvica
  • 167 Answers
SOURCE: I have a HP Photosmart
You need to calibrate your cartridges. To adjust color's in setup cartridges.
It' in printers and faxes.
good luck
Posted on Sep 15, 2008
  • 1218 Answers
SOURCE: We purchased a HP Photosmart
Black printer ink in HP Photosmart may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Posted on Oct 13, 2010
Slasher_X
  • 767 Answers
SOURCE: Hi, my i450 has suddenly stopped printing both
Sometimes the cartridge has a little piece of plastic covering the part that puts the ink on the page. Check that this is removed as it could be causing a blockage.
Posted on Mar 10, 2011
My printer HP photosmart plus B210 series displays error message
>> Remove the print head and gently clean the head.
>> Check is there any obstructions on it.
>> Turn Off the printer for 2-3 minutes and turn On.
>> Re-insert the print head and check the status.
It may help.
Nov 25, 2013 | Computers & Internet
HP photosmart B210 wont print black
Seems to be a common problem - I had it too. I spent a lot of time looking, but never quite found a consistent fix. I fixed mine in a few steps: First, I removed all the cartridges, and cleaned the filters on the top of the printhead (these are the little screens you see when you look at the tray with the cartridges removed). To do this I blotted each screen with premoistened alcohol wipes, changing wipes frequently, until the wipes were clean. I then removed the printhead by lifting the black handle on the right side, and lifting the printhead straight up. I used alcohol pads on the rear contacts (refer to HP's instructions for changing printheads) in a downward motion only. Finally, I cleaned
Nov 10, 2012 | HP Photosmart Plus B210A Multifunction...
Can you print two sided
yes... go to start, click on printers and devices on your computer, right click on the printer you want to use' select properties, then select two sided printing....
Jul 14, 2012 | HP Photosmart Plus All In One Printer b210
My printer screen says
The ink is contained in a cartridge.
Note that "backup" printing mode mixes colours, to produce "black", because the "black" ink-cartridge has failed.
So, replace the BLACK ink-cartridge.
Jan 05, 2010 | HP Photosmart 8150 InkJet Printer
Hp photosmart 335 - cartridge failure
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart 335 InkJet Printer
Printer does'nt work with non H P cartridges
It is pretty clear that you have a defective color cartridge. Return it to your vendor for a replacement. You may have some success cleaning the contacts as shown here, but most likely you need a warranty replacement color cartridge.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Aug 25, 2008 | HP Photosmart C4280 Aio Printer
My HP PhotoSmart 7762
I have a hp printer photosmart 7762, during traveling my power cable and tried every way I could to buy a secnd hand including buying another similar printer which I failed. Please help me. **** nazymharris@ukgateway.net
Oct 28, 2007 | HP PhotoSmart 7760 InkJet Printer
Open Questions:
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
