Question about Samsung RB195ACWP Bottom Freezer Refrigerator
Will not dump ice
I can get it to work if I hold the button on the bottom of it. it wont do it by its self
3 Suggested Answers
  • 1531 Answers
SOURCE: ice maker wont dump ice. it will refill with
need to replace the ice maker
Posted on Sep 27, 2009
  • 3 Answers
SOURCE: ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
Posted on Sep 24, 2010
Ice made but will not dump.
Hello, There is a heater in the bottom of the tray where the ice cubes are formed. The heater melts the bottom of the ice cubes just enough to release the ice cubes from the mold. I suspect your mold heater is not working.
Oct 13, 2015 | Refrigerators
Status light solid red, with blinking.diagnostic blank wont reset
Push and hold the off button for 4 secs then freeze button but chances are itll happen again until problem is corrected
Jul 15, 2015 | Scotsman CU1526SA-1A 150 Lb Self-Contained...
Model CME256AS-1D will not go back into freeze cycle and will eventually stop, requiring the unit to be reset.
So is the unit going into a harvest and not going back to a freeze cycle? dose it dump a batch of ice but wont go back into a freeze cycle? before you reset it have you pulled the front cover to see what code it is giving? any time you have to reset it that means it locked its self out on a fault. if unit freezes and go's into a harvest and dumps the ice but dose not go back into freeze cycle check the door switch when the ice dumps the deflector door opens a magnetic switch which tells the board the harvest has finished and then the freeze cycle begins. Now if there is no ice falling off the plate to open the door then the board will time out and try 3 more times to make ice before it locks it out. the same go's for the harvest.
Jan 08, 2014 | Scotsman Cooled Modular Contour Cuber Air...
The ice maker will make the ice but I have to manually press the reset button to have the ice dump into the tray. It will not dump ice on its own. This is for the samsung RF217AB french door bottom...
Make sure the freezer is cold enough. If not this might cause problems of poor dispensing.
If your ice makes unit has a 'heater'build into it, it just might be that the heater in the tray does not work..if so, new ice tray dispenser.
Oct 25, 2013 | Samsung RF217ABWP (20 cu ft) Bottom...
Lfx25976st
Could be an open circuit to the ice tray sensor. This is the wire under the ice tray. It is flexed during each cycle and can fatigue easily. I found this condition on a three year old unit. A simple solder repair and heat shrink tube corrected the problem.
Jul 26, 2012 | LG LFX25971ST Bottom Freezer French Door...
My icemaker just stopped making ice - i can feel frozen ice in the top but it doesnt dump any ice out?
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 13, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
NO ICE IN MY BOTTOMFREEZER AMANA REFRIGERATOR
If we both are on the correct subject then it is possible the water control valve on back of refrigerator is not working. If ice tray is dry then fill with water from a cup and let freeze. If the ice maker dumps the ice let me know and we will go from there. Sea Breeze
Apr 26, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker not working
If you press and hold the button on the ice maker for seconds it will go into test mode and do a complete cycle. Try this and it should correct the problem. If you think the arm is frozen, you could use a hair dryer on it for a couple of minutes then do the test.
Sgt 48
May 20, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Samsung RB195ACWP Bottom Freezer Refrigerator Logo
19 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
