Question about Stryker Mx-pro R3 Accessories Domestic Restraint Package - Model 6082-
Release handle wont release
When loading cot into a vehicle the release handle does not engage to release the latch mechanism.
My boot wont close fully
  • Press down on your trunk, and have somebody release your trunk's release mechanism from inside your car simultaneously. These systems can become jammed but can sometimes be released if a gentle downward pressure is applied to your trunk while the mechanism is being activated. If this is the problem, apply some lubricant.
  • Clean the latch and the area where it connects to the chassis. If dirt or debris has become lodged here, it can stop the latch from connecting properly. It's a good idea to vacuum the area to ensure no small bits of gravel have become trapped and stopped the mechanism from securing properly.
  • Examine the latch and the area where it connects to the body of the car. Either of these might have become bent out of shape or damaged in some other way if the trunk has been shut with an obstruction in the way. If this is the case, contact your vehicle's manufacturer or a local garage to find a replacement if the elements cannot be repaired.
Check the latch mechanism, it may have accidentally already be in the closed or lock position. If it is, you will have to pry down on the latch tangs with a screw driver while pulling latch handle to the open position.
Latch could also be seized, in that case , use a thin oil liberally on latch mechanism, and work the mechanism open and shut closing and opening with screw driver and boot handle.
How to fix trunk that won close 2006 2008 civic for less than 5
Jan 23, 2016 | Skoda Superb Cars & Trucks
Power lift gate will not operate
You have to pull the inside door panel off an check it out , only way !
  • The lift gate latch release is inoperative/does not operate correctly
  • Circuitry
  • Liftgate release switch (integral to the liftgate release handle)
  • Liftgate release motor (integral to the liftgate latch)
  • Power liftgate module
  • SJB
  • Go To Pinpoint Test F .
Normal Operation The smart junction box (SJB) does not release the liftgate unless the doors have been unlocked electronically or the request is initiated from a remote keyless entry (RKE) transmitter.
The SJB sends a voltage signal to the liftgate release switch (part of the liftgate release handle) through circuit CPL45 (BN). When the switch is activated (the handle is pulled), the signal is routed to ground through circuit GD150 (BK/WH). When the SJB detects a request from the liftgate release switch, the SJB provides voltage through circuit CPL10 (BN/BU) to the liftgate latch release motor (integral to the liftgate latch) (vehicles with a manual liftgate) or the power liftgate module (vehicles equipped with a power liftgate). For vehicles with a manual liftgate, ground for the liftgate latch is provided through circuit GD150 (BK/WH).
DTC B2666 - is an on-demand DTC that sets when the SJB detects a short to ground from the liftgate release switch input circuit.
DTC B273A - is an on-demand DTC that sets when the SJB detects a short to ground from the liftgate latch release output circuit.
DTC B273B - is an on-demand DTC that sets when the SJB detects an open or short to voltage from the liftgate latch release output circuit.
    Possible Causes
  • Circuit CPL45 (BN) open or short to ground
  • Circuit CPL10 (GN/WH) open, short to ground or voltage
  • Circuit GD150 (BK/WH) open
  • SJB
Your best bet is to take it to the dealer !
Nov 04, 2015 | 2008 Ford Expedition Eddie
How do I open hood when cable or latch is broken
If the plastic hood release handle inside is broken, can you reach the steel cable, if so, use a pair of vice grips to grab the cable and pull. Sometimes it helps to have a helper standing at the end of the hood and pop the hood with palm of hand, in the area of under hood release mechanism, at the same time your pulling the cable.
If cable is broken, some makes and models, you can remove front grille and get at under hood release mechanism.
There is usually a primary hood release, inside vehicle, and a secondary release under the hood, you have to slide your hand under the hood to release, sometimes you have to press down on the hood a little to move release. Trying to shut the hood with secondary release engaged can be difficult, you don't have the distance and the weight of hood to swing down.
Nov 04, 2015 | 2007 Chevrolet Chevrolet HHR LT
Locate trunk latch for dodge charger 2014
I'm not sure what you're definition of trunk latch is so let's cover all the bases.
The trunk latch mechanism is inside the trunk well. When you open the truck lid, look down, right in the middle of the back lip that you would have to lift things over to put them in the trunk. The latch mechanism is right there in the middle. While you are looking in the location, look just to the left as you are standing behind the vehicle, and you will see a handle kind of like the pull handle on the end of the cord for your walk behind mower. That is a glow in the dark, emergency pull release for the trunk latch. If you or a child ever got caught in the trunk for some reason, you can pull that handle to manually operate the trunk latch to allow you to open the trunk lid.
On your key FOB, you have a trunk release button as well. If you push that button twice within 5 seconds, the trunk latch will release. You also have a trunk release button to the left of the steering wheel. It's a round button with a picture of a car with an open trunk lid. You can push that to open the trunk lid as well. To use the button inside the car, or the one on the key FOB, the car must have the transmission in park. It will not release the trunk latch if the vehicle is in gear.
Jan 19, 2015 | Dodge Cars & Trucks
Drivers seat won't latch
Will it latch if you push the release handle down, you know opposite of trying to get it to release? It might be a broken or dislodged retaining spring that pulls downward pressure on the release handle. If this is not the problem then the teeth on the gear that the release handle engage are possibly worn out.
Apr 22, 2013 | 1999 Toyota Camry Solara
How does a manual top work on a 1998 BMW 323 I??
I believe you do this in this order. Roll windows down, release the latch at the top of the windshield, raise the front of the top, release rear cover by pulling the latch near the rear seat, Pull up the back of the top and then pull up on the rear cover. The back of the top should now fit into the opening under the rear cover. Continue to fold the top into this space. Push down on the rear cover to lock (won't be able to open trunk if not engaged.) To raise it, release rear latch cover, open rear cover and pull top out of opening. Raise rear of top so you are able to now close the rear cover, set rear of top down on cover and then pull fron of top down and engage the fraont latch. Hoe that helps.
Jan 23, 2013 | 1997 BMW 318
Fix broken rear hatch handle
will need to remove the rear panel to access the latch mechanism the release bar connector either popped off or broke the clip is only a few bucks and is easily replaced the hassle is in the removing of the panel
Nov 19, 2011 | 1999 Ford Explorer
Drivers side door wont latch shut on 97' Ford F150,HELP!
Ouch, this has happened to me before. Don't panic!, it's pretty easy to cure...for the moment. It's pretty likely what has happened is the latch has somehow been tripped, causing it to collide with the latch post (looks like a bolt with a round head on the door jam). Look at the latch itself, on the door, and be sure it isn't closed, it should have a bit of a gap to allow the latch to engage the post and trip the mechanism that causes it to lock, holding the door shut. IF the latch has been tripped, then you will need to make certain the door is unlocked, and pull the door release using the inside handle, and using a screwdriver or another practical item other than your finger, carefully try to push the tripped portion of the mechanism toward the car, so that it will release. It shouldn't take a huge amount of effort, if it hasn't been badly damaged. I hope this helps, and if you need video for clarification, I'll be happy to do so, just let me know. Good luck!
Feb 11, 2011 | 1997 Ford F150 Regular Cab
My jaguar trunk want open because some slammed it shut
There is a possibility that there is an object in between, creating pressure from inside so the latch is stuck engaging the striker. (these objects may be the carpet, wires, the body seal, etc)
First: Push down the trunk while you unlock it.(while you doing this you may listen a mechanical click that means that latch release the striker.)
Second: At the same moment you listen the opening noise, release the push down pressure and pull up the trunk open.( perform this until you achieve the right timing the latch job is to comeback and engage the striker so do it several times).
Another scenario if you have an electronic actuator.
First make sure you that when you press the remote or switch for the trunk there is a little click, if there is a click use the technique above push trunk lid and at the same moment that clicks pull up the lid releasing the pressure down.
And the last option almost all the vehicles had the option to access the trunk from the back seat, and almost all vehicles have a release handle to bypass mechanical latch or electronic actuator.
Dec 19, 2010 | Jaguar XJ8 Cars & Trucks
2002 Explorer rear liftage latch replacement
Liftgate Latch Remote Control Removal and Installation
  1. Remove the liftgate trim panel. For additional information, refer to Section 501-05.
  1. Remove the watershield.
  1. Disconnect the actuator electrical connectors.
  1. Disconnect the liftgate window glass latch release cable.
    1. Release the cable conduit.
    1. Disconnect the cable.
  1. Disconnect the liftgate latch release cable.
    1. Remove the cable conduit.
  1. Release the exterior liftgate release handle actuating rod.
    1. Open the clip.
    1. Release the rod.
  1. Remove the bolts and the liftgate latch remote control.
  1. To install, reverse the removal procedure.
    • Transfer parts as necessary.
Jun 01, 2009 | 2002 Ford Explorer
Stryker Mx-pro R3 Accessories Domestic Restraint Package - Model 6082- Logo
136 people viewed this question
Top Stryker Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Stryker Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
