Auto programming channelsI am trying to autoprogram my NEC TV, but it keeps getting stuck at 26%. I already had the Tuner replaced by NEC and the new tuner is still having the same problem. I have tri
Tuner: SB-03TM TV: MEC Multisync V463
4 Suggested Answers
SOURCE: digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Posted on Sep 24, 2008
sams_trix
  • 93 Answers
SOURCE: what is the difference between HRC, IRC, Std and
Usually standard broadcast is is the default setting,some other cable company use HRC and URC, these are ways to transmit or deliver their signal trough cable wire,ask comcast cable for their transmission type.
Posted on Aug 30, 2009
dduncan774
  • 760 Answers
SOURCE: GV42L vizio tuner
Your vizio has an internal digital tuner. When you are on air, make sure that it is set up for digital. It might say DTV. Some sets have an analog only and digital only program option in the user menu, or as a seperate input. When in doubt, check your user manual.
Posted on May 02, 2012
No signal....stuck on ch 1
Your TV will only do what it has been told to do.
If it has never been programmed for cable, it is doing just what it has been told. NOTHING. Or if someone did auto program the TV without the cable connected, it went all the way through the channels and remembered only those that were there. NONE
With the cable connected, go to TUNE A CHANNEL, and AUTOPROGRAM. (you may have to choose AIR / CABLE before it will AUTO PROGRAM)
Do not stop it or interrupt it until it is finished.
Apr 02, 2013 | Televison & Video
GV42L vizio tuner
May 02, 2012 | Vizio GV42L 42 in. LCD Television
Accidentally pressed a button on the remote which has returned our 26' dynex rc701da hdtv to setup mode cannot get it set up again despite following instructions always ends up "plse run channel auto...
Hi:
The unit is telling you to run autoprogram to program in your channels, make sure also the TV is in cable mode and not TV mode which is for local channels, If you have cable do a autoprogram so the set can program in channels. Auto Scan is the same as autoprogram.
Mar 17, 2011 | Televison & Video
We have not had this tv on since went over to digital freeview built in hopwever just put it on and there are no channels stored how do we get channels?
Hello
Your TV has to be initilized. It should be retuned to get the channels memorized in its memory section. Then only you can get the channels stored. Hopes that you have its remote control hanset with you. Replace two new cells in it and proceed the folloing steps. Connect ariel to its back socket before doing these.
[1] Press power button on the front panel of your tv. The initial setup screen appears.
[2] Press Ch+ on the remote control handset or on the front panel of your TV to start auto program, or Ch_ button to exit.
The initial setup screen will appear each time you switch on the tv until you perform autoprogram.
To perform autoprogram again
[1] Press Menu button.
[2] Press to highlight Channel Menu
[3] Press Pr Dn button to hilight cable. Press [+] to select.
[4] Press Prog Up or Prog Dn to hilight On or Off according to how you connected your TV. Press [+] to select.
[5] Press Prg Dn to hilight autoprogram. Press [+] to search for channels.
[6] After autoprogram finishes, press "Menu" again to exit.
TO RESET THE TV TO FACTORY SETTINGS
[1] Turn TV on.
[2] Press and keep hold the "Reset' button on the remote control hanset.
[3] Press and release the "Power button" on the TV front panel. The TV will turn itsef off.
[4] Release "Reset Button" now from your hanset.
These are the processes to be done to either autoprogram or turn it to factory settings. Ok.
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I cann;t receive several network channels on my Dynex 26: L150A11 LCD TV using only an antenna (no converter box). Does this TV have a built-in digital tuner? Do I need to use anything else to connect ?
all new tvs should have a built in digital tuner. Make sure that tv is set to receive antenna signal and not cable by going into the menu. Use autoprogram feature if you haven't done so already. it will lock onto whatever signal is strong enough for it to see. Also if you are using an indoor antenna it may not be able to get enough signal to the box. Indoor antennas are not the greatest especially if the station is far away.
Sep 11, 2010 | Televison & Video
Cannot program all cable channels into tv.
is it keeping low channels or high channels because you have diffrent tuner bands may be eeprom also
Apr 03, 2009 | Televison & Video
Any idea why on my new sharp 32" lcd tv, all cable channels except 57 & 58 (CNN) work fine, but on these channels the sound goes off and on, like there is a short in the sound. all other tvs and cable work...
If you do not have problems with picture and sound on all the other working channels, then the problem you are having with 57 & 58 cannot be a short. The problem you are having is that those channels will not tune in properly through your tuner and this is why you get intermittent sound when they are trying to tune in. The sound tunes in easier than the picture. You said that you have programmed the channels again and I am assuming you are talking about the autoprogramming mode. Try to program those channels individually by deleting them and then readding them. If you cannot do that then you need to take the tv back since it is new or have warranty service look at your tuner and setup your tuner by making adjustments to it directly. Good luck and God bless.
Jan 22, 2009 | Televison & Video
GE 20GT320 TV
don't use auto programme.
use manual or semi auto.
you have to press the auto programme button a few times.
Jul 12, 2008 | GE 25GT270 TV
Channel
make sure that ur antenna/catv is properly connected to antenna/catv input of ur tv...better check the center lead if ur using coaxial cable..then try to reprogram/autoprogram ur set.
navigate also on tuner settings...via remote..
if u get nothin after autoprogram..probably bad tuner in ur set..u need a prof tech to fix it...thanks hope this help
Feb 05, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
