Question about Dell Office Equipment & Supplies
When i print any document, it has random gray squares all over the pages. Have deep cleaned and aligned the printer with the same results. can you help me
My printer is a Dell V313w
  • 5 Answers
SOURCE: Printing alignment problem
First thing to try is to remove the power brick (not just the cord the whole brick) from printer for a minute then re insert and try it again. If this doesn't help try uninstalling it then re installing the printer
Posted on Oct 14, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
Gletkin
  • 49 Answers
SOURCE: After deep cleaning the print heads, it will only print one page
This sounds like the print head alignment is not stabilized and may indicate you need a new print head ($$$). Try looking in the Service Manual.
A copy of the Canon i860 Service Manual is downloadable at:
http://rapidshare.com/files/179582794/Canon_i860__i865_SM_-_printer1.blogspot.com.rar
The password to open the compressed PDF file is: printer1.blogspot.com
Posted on Feb 24, 2009
SOURCE: Canon Pixma ip3000 printer, changed black ink
i had the same problem and just repeated the cleaning and testing, eventually the black showed up but took more than a few repetitions
Posted on Jun 30, 2009
duane_wong
  • 6826 Answers
SOURCE: My Cyan cartridge is producing streaky results -
Are you using genuine Cyan cartridge from Canon? or aftermarket?
Posted on Aug 03, 2010
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
How to remove printhead
Alignment shows black & streaky, only covers 3/4's of a line, color is good. The printer copies a document no problem; but only copies color (no black) from the computer. If the document is black print, I get a blank page. Do not know how to remove printhead
Jun 29, 2013 | Dell V313w AllInOne InkJet Printer
Blue cartiage not lining up right
Update the firmware http://bit.ly/HKXTr7 .
After successfully updating your printer, run the Deep Clean Printhead function on your printer. Press the Setup button > Maintenance > Deep Clean Printhead.
Please scan and email us a test page ( Press the Setup button > Maintenance > Print Test Page ) from your printer after the update so we can evaluate the result. Please send it to LxkListens@Lexmark.com.
Aug 19, 2012 | Lexmark Impact S301 Wireless All-in-one...
When I print colored squars show up in the background
Update your printer firmware http://bit.ly/JqfYcG
After successfully updating your printer, run the Deep Clean Printhead function on your printer.Press the Setup button > Maintenance > Deep Clean Printhead.
If you're still having problem, please scan and email us a test page (Setup button > Maintenance > Print Test Page) to LxkListens@Lexmark.com.
Jun 04, 2012 | Lexmark Intuition S505 Wireless All-in-One...
HP Officejet Pro L7780 all-in-one, Windows Vista, set up as a wireless network printer, prints multiple copies of test page and also other documents, when only one is selected both at the computer and...
this is a simple problem, the technology that printer aligns its print head automatically by the reading the align page, if your printer head are not in good health/clogged align print wont come properly result align pending..When printer gets power on its prints align page till align completes. Go to tool box in system all programme, perform clean print head, check the quality of printer outs then ask to printer to align.. if its not completing replace print heads..
Sep 10, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I have two cartridges in my 5610 a #22 color and a #27 black. I received a low ink message, but didnt know which one was low. I noticed that the most recent Word document looked fuzzy so I replaced the...
Hi
You can bypass the alignment on 5610 by pressing ok to start alignment
and then cancel
after that check by printing a document if your cartridges work fine if not
you can refill them with this easy and cheaper method
Jan 19, 2011 | HP Officejet 5610 All-In-One InkJet...
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
My MP830 leaves white horizontal bands when printing black & white documents. Color printing seems fine. Pattern 'F' is missing on the print alignment page.
You need to continually clean and deep clean and realign the black until the results are acceptable. Try manual alignment if the auto does not work. Also clean around the exit hole of the black ink cartidge with a cotton bud and isoproyl alcohol.
Nov 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
13 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
