Question about Garden
Diagram for a 24 inch poulanPro snow blow pro
Auger belt and the size
Biggdex35
  • 333 Answers
SOURCE: I have a Skil 4
18 inch is the biggest I seen however I couln't find your model number. Here is a site tell you evertthing You need to know.
http://www.ereplacementparts.com/
Posted on Oct 06, 2010
  • 4088 Answers
SOURCE: my yard master 5.5 horse
Assuming that you mean that the engine bogs down, try increasing the main jet setting by turning the screw CCW (looking at the outer end of the screw) somewhat. If no help, the carburetor may need cleaning to allow more fuel to the engine. Make sure the muffler and fuel filter aren't plugged. Hope this helps!
Posted on Dec 27, 2010
  • 4088 Answers
SOURCE: I have a arien snow
Run the impeller without any snow coming into it--hold your hand over the exhaust of the impeller to check for considerable wind force. If almost non existent, make sure the impeller is being driven at full speed. Is there a shear pin related to the impeller? The only other problem would be if the impeller was running the wrong direction, but I don't see how that would be possible. Hold the impeller with your hand while trying to turn the pulley--there should be no slipping between the two. Hope this helps!
Posted on Jan 04, 2011
  • 4088 Answers
SOURCE: We have just installed the
This appears to be a Sears model number--go to: www.searspartsdirect.com and enter the model number minus the decimal point. This will bring up a series of drawings of all of the replaceable parts for the machine. Locate the pulley that you speak of and see if a 'key' is shown to lock the pulley to the shaft. Hope this helps!
Posted on Feb 01, 2011
  • 4088 Answers
SOURCE: The blower won't throw snow
If the belts are intact, then NAPA or a hardware store should be able to replace them. If they are shredded, then you should order them from Ariens. Good luck!
I just replaced the auger belt and the auger cable has no tension. What do I do to fix it?
Here's some silly questions: Did you put the belt on the correct side of the Tensioner?
Is it the correct sized belt?
Is there a spring on the cable for the auger that can be lifted up the cable to expose the adjustment nut ?
Feb 08, 2016 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
The auger is no longer turning. How do I fix it?
Check for broken shear bolts first. Then, move on and check the auger belt. Finally, if all those are ok, check the gear housing on the auger drive shaft (right in front, between the two auger blades).
Feb 02, 2016 | Poulan Pro 24-Inch 208cc LCT Gas Powered...
Poulan snow blower p055te24.auger does not turn.shear pin on auger does not turn.how to get auger shaft off? gbethune10@yahoo.ca
GO TO GOOLGE ANDTYPE IN THE QUESTION YOU TUBE WILL HELP YOU IN THIS PROBLEM I HAVE USED THIS ON OTHER PROBLEMS AND ITS HELPED ME OUT
Feb 10, 2015 | Poulan Pro 24" 2Stage Snow Blower Electric...
Auger won't stop
Open up plastic cover over belts.There is a pulley that moves against belt to engage front auger.There is a spring that hold it in the off position and when you pull the handle it moves that pulley.Sounds like spring broke or slipped off.
Mar 23, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Impellar will not turn
pull the belt cover off and check the belt if it is ok the key in the beltvpulleyb that drives the auger could be sheared
Mar 13, 2014 | Poulan Pro 24" 2Stage Snow Blower Electric...
Need belt size for poulan pro 96194007 snow blower
Is there a part number on the belt itself? Try googling the model number and putting in belt.
Mar 01, 2014 | Poulan Pro 24" 2Stage Snow Blower Electric...
Snowblower doesn't throw the snow very far, and every time I stop it, it takes a while for the auger to start turning fast enough to blow the snow. Feels like the torque isn't there. This is a Husqvarna...
The most common cause of this is the drive belt is worn.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission.
With the engine not running, have someone depress the drive lever and check the blower belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
You can get parts for you Craftsman and most Husqvarana, MTD made models through searspartsdirect.com. You can also get parts through jackssmallengines.com or your local dealer.
If you are unfamiliar with repairing machines take it to your local dealer. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions to troubleshoot this problem farther. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Garden
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
