SOURCE: TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
SOURCE: Thermador Microwave Oven Model MBBS Serial No FD
Oh dear, I hope the magnetron still works. That plate you describe is called the Waveguide Cover. This cover must be kept clean otherwise the food particles will carbonize and cause exactly what you have described.
Contact the manufacturers web site for a supplier in your area or look on ebay, espares.co.uk depending on your location.
When it has been changed, I hope the magnetron/aerial is OK.
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
