Question about GE Refrigerators
Hotpoint HSS251FMD-WW Fridge is warm
I have a Hotpoint side by side Refrigerator model HSS251FMD-WW. The Refrigerator side is warm, but only on the top of the fridge. I have thermometers in the upper and lower portions of the fridge, as well as the freezer. The Freezer is extra cold, and the fridge is frozen at the bottom, 40 degrees in the middle, and over 50 at the top. I'm convinced the refrigerator is quieter now too, so I think it's either the evaporator fan or condenser fan? I'm a complete novice though, any help would be much appreciated!!
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
duby1990
  • 367 Answers
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
Maytag317
  • 1136 Answers
SOURCE: freezer cold, fridge warm
Hi, You have a self defrosting problem.
Remove the rear inside freezer panel and check continuity on the defrost element and bi-metal switch.The bi-metal has to be tested cold. If there is continuity on both parts, you will need to change the defrost timer.
The most common part that goes bad is the element. I hope this helps you. Please leet me know if I can assist you further.
Vic
Posted on May 28, 2009
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
  • 6 Answers
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Posted on Jun 13, 2010
After a moving to a new city, we had our Hotpoint model HSS251FMD WW refrig in storage for 4 months. When I installed it in our new house it will not cool. Is there a reset button?
flush the refrigerant by nitrogen & refile new refrigerant.every work doing by qualified technician.my be some compressor oil over com in freezer
Jan 03, 2011 | Hotpoint Refrigerators
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I have a side by side Hotpoint model #HSS251FMD.The water dispenser stopped. Replaced filter and now no water or ice.
sounds like the water inlet valve is not letting the water come in. need to check and perhaps replace this valve. hope this helps.
Oct 13, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Hotpoint fridge problem, warm fride, but freezer working good
Fridge along bottom shelves is much colder than the very top shelf which has milk etc., leading to spoilage. Fridge is at highest setting. In the upper left rear of the fridge compartment, is a cover for what I believe to be a circulatory fan. However, trying to remove this cover is difficult.
It seems that the clip nuts to which the two (2) small capscrews fasten are free wheeling and not allowing me easy access to the motor.
Please advise.
My model no. is HSS221FMD WW
Jul 20, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer is completely covered with white ice
sometimes a faulty door rubber can make the freezer work overtime. Does the door close firmly?
Oct 25, 2008 | Refrigerators
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
