Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Ge profile top loading wpgt9150 won't drain and spin
MNTECH
  • 1543 Answers
SOURCE: GE Profile WPRE6100G Top Load Washer
The most likely cause of your problem is the lid switch.
Posted on Oct 27, 2008
drsn
  • 42 Answers
SOURCE: GE Profile top load washer wont drain or spin
SOUNDS LIKE THE LID SWITCH IS DEFECTIVE, ITS A SWITCH THAT CONTACTS WHEN DOOR CLOSES, THEN RELEASES CONTACT WHEN DOOR OPENS. HAVE A PRO CHECK IT AND REPLACE OR BYPASS IT.............
Posted on Dec 14, 2008
  • 42 Answers
SOURCE: I have a ge profile
I would check your belt. From what you've told me, your electric pump is working and receiving power from your lid-switch, but your motor and transmission is not turning/agitating.
Meaning, your belt is most likely, NOT engaging or grabbing your pulleys to rotate the motor/tranny. Belts will ware and tare, just like your vehicle fan belts. Change it! You should be good!
If not your belt, your lid switch may be the culpret. However, from what you've described; very unlikely because your water pump is turning on and receiving power from the "lid-switch". The switch becomes defective after constant use and slamming/dropping of the door. The purpose of the lid-switch is to prevent accessing your clothes when in spin-cycle (dangerous)
Posted on Jan 26, 2009
mgprice
  • 744 Answers
SOURCE: GE Profile wont spin,why?
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wiring to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you replace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Thanks for using Fix-ya. A high rating would be appreciated for your free question :)
Posted on Jul 26, 2009
  • 3600 Answers
SOURCE: Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Posted on Sep 10, 2009
Testimonial: "thankyou for the help, I thought I had just made a bad buy. They sent someone out right away and it turns out this particular machine had a bad part."
Ge front load won't spin
Does the drum turn at all? if not it will be the motor brushes, Also check the drain pump for blockages and make sure the pump is functioning.
Mar 12, 2012 | GE Washing Machines
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
Our ge washer will not drain water out before it goes to spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 23, 2011 | GE Profile WPSR3120WWW
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
heatman101
Oct 03, 2010 | GE Profile Prodigy WPSE4200A
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Dec 14, 2008 | GE Profile WPRE6100G Top Load Washer
Oct 27, 2008 | GE Profile WPRE6100G Top Load Washer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
83 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
