Question about Dryers
My Kenmore dryer model 11092832100 had a burned out light bulb and when I put some clothes in the dryer the light bulb sparked then my dryer wouldn't start at all. The repairman said I needed a new circuit board so I replaced that. The dryer started up then after one minute gave an E1 error code. After some more troubleshooting I replaced the thermistor. I am still getting an E1 code--what now?
dididsaythat
  • 291 Answers
SOURCE: Error Code E1
got a model #
Posted on Sep 02, 2007
SOURCE: Error Code on LG Dryer
The solution is not the thermister it is a board in the console with the transformer on it. That's what my tech says.
Posted on Apr 29, 2008
jyackle5
  • 8197 Answers
SOURCE: I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Posted on Dec 18, 2008
Greg20
  • 149 Answers
SOURCE: kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Posted on Jun 12, 2009
jyackle5
  • 8197 Answers
SOURCE: PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Posted on Oct 05, 2009
Kenmore dryer model 110 leaves burn marks
They aren't burn marks, it is the clothing getting pinched between the drum and the bulkhead due to a worn felt seal. Help Me Find My Model Number RepairClinic com
Oct 17, 2016 | Kenmore Dryers
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
Lights in my kenmore refrigerator, freezer on bottom, burned out. I purchased two 60w bulbs and replaced them. I plugged in the refrigerator and the lights were on. Then a couple of minutes later,
Hello Sharon;
My name is Peter. I am a retired field service refrigeration technician.
You can not put normal house hold appliance bulbs in appliances. There are special bulbs for refrigerators, clothes dryers and close washers.
The bulbs are usually available in the local market and marked; "Refrigerator" and Freezer".
You may have a bad door switch. But, I am more prone to go with the wrong service bulb.
Your Friend,
Peter, Baltimore, Maryland, USA
Nov 16, 2014 | Kenmore Refrigerators
Kenmore stack dryer burns clothes
HI CAROMIA.unusual but check basics first1-dont overfill 2-no sintetics and nylons.if still burns its obviously overheating.3-check vents.hope this helps.ali
Jun 20, 2012 | Kenmore Dryers
I do I get the cover of the light to change the bulb in a kenmore 96589410 dryer. Its located to the right side of the door, one screw which I took out, but don't seem to be able to get the plate off to...
I had a bulb burn out on the same model.
take the screw out..grab the bottom of the plastic cover and pull straight down.
It fights you, but it'll come off with a little effort.
Putting it back on and lining up the screw hole is fun also.
Apr 12, 2009 | Dryers
How old is a model 96583100 kenmore dryer ?
Why do you need to know this. Go to www.repairclinic.com and enter your model# you'll find parts for it. Chances are it needs a good cleaning. Good Luck. NVER STORE CLOTHES OR ANYTHING ON TOP. Why? It burns them up. They need to disapate the heat
Feb 19, 2009 | Kenmore 63942 Dryer
Heating element and/or replacement bulb
no light bulbs on its own line and routs through the door switch as for the heat check your temp select button or your thermostst in the control panel should be a tech sheet with specs but be sure to put it back when your done
Feb 11, 2009 | Kenmore 63942 Dryer
Where buy light bulb (120V, 10W) for GE dryer Model DPSR10EG5WT ? Bulb burned out after 30 days of dryer use.
go to sears .com click on parts, put your model number in and all the parts for your dryer will come up,let me know how you do-mike
Oct 01, 2008 | GE Dryers
Light bulb
Sounds like you got a defective bulb. Make sure it is for 120 volts or thereabouts....not 6 or 12.
Jun 19, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Dryers Logo
Top Dryers Experts
