Question about Watches
Replace firing pins in my fausti over/under - Watches
Under sniper fire
Stay low and under cover. Put something out for the sniper to shoot at and at the same time, get an oppo to look for the flash from at least 30 feet away. Call in air support or a mortar team.
Unless you are on the other side, in which case pull the pin on a grenade, count to 20 and throw it. :>)
May 06, 2016 | Watches
Shell does not eject slide jams..I pull clip, pull slide back a couple times , shell ejects what is my problem
Hi! Kevin.....bit hard to know !....assuming ammo is correct dimensionally & of good power., & extractor & ejector are in order & chamber is good & slide is free & full sliding......then my first guess would be sticky firing pin not retracting properly thus stymying ejector action.......any stickier & you might get full auto ?......are you puncturing primers ?.. if gas back escape is part of the picture , bullet may not leave barrel . I suggest you do full strip , incl firing pin , clean & remove any burrs ..... worthwhile to run some dummies by hand & see how they behave..........jimbanjo
Jan 16, 2014 | Smith & Wesson SWW-357-R
I HAVE A NIKE WATCH WA0022 AND THE BAND IS BROKEN WHERE CAN I BY ONE
The model name is: Oregon Analog Chronograph
The band on this model is a pin-less design and the band cannot be replaced by the consumer. The watch may be sent to http://parsecent.com/ which is the authorized Nike watch service center and replaced for free if under warranty still (2 Years). They can also replace for a fee if outside of warranty. See here for information and tool purchase. http://www.easycarts.net/ecarts/ShoppingCart/Oregon_Series.html#WA0022
Apr 29, 2011 | Nike WA0022-002 Wrist Watch
How do I replace the battery in my FS4389 watch?
IF YOU TURN YOUR WATCH OVER YOU WILL SEE A GROOVE . IF YOU FIX A PIN UNDER IT .IT WILL PRISE OPEN AND YOU WILL BE ABLE TO GET ANOTEHR BATTERY YOU SHOULD BE ABLE TO PICK THEM UP IN TOWN CHEAP WITH-OUT GOING TO A JEWELLARY SHOP ,HOPE THIS HELPS
Jan 28, 2011 | Fossil ES2519 Watch
I have a TIMEX Ironman 30 lap watch and am trying to replace the watch band. I can't get the 2nd side in. Is there a trick to line up the pin with the hole?
This is how I do it:-
Put the pin in the strap, put one side in (that's easy) then holding the other side against the watch just above the receiving hole, press the end of the pin with a small screwdriver.
(When the pin is inside the watch it will slide towards the receiving hole under the gentle force you are applying.)
It may take more than one attempt but keep trying!
Mar 16, 2010 | Timex Marathon Fullsize Watch
HOW IS A STAUER NOTCHED LEATHER WATCHBAND REMOVED
These sound like standard spring loaded pins.
To remove them I use a small screw driver and press it gently against one end of the pin, while pushing it lengthwise.
This compresses the spring and allows the pin to pop out.
(take care where you do this as it may fire out and get lost).
It may take several attempts to get pins out, as you have to experiment with the forces applied to get the right balance.
Putting the pins back in is also a skill. putting the pin into the strap, put one end into it receiving hole and press the other end as far as you can. Move the end in line with the other receiving hole and remove screw driver. It sounds easy but takes a little practice!
Jan 05, 2010 | Watches
Relic watchband that isn't the same as instuction book
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Feb 15, 2009 | Relic 0504648FA
Watchband replacements?
On ebay you will be able to find the correct Casio band for your watch. There are 2 or 3 dealers that sell them but a little advice....don't buy the cheap ones! Buy ONLY the Casio replacement band and it will fit perfectly. You will need the spring bar tool to remove the pins that hold the band to the case. Don't try to install or remove the band without one....it will gouge the case at the pin stems and you will not be happy. They are cheap and worth every penny. Casio.com can also direct you to their watch bands. Hope this helps you and good luck!
Dec 11, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Casio G Shock (Model G2300)
you have to remove the pins located under the band
Feb 26, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
