Question about Stoves Kitchen Ranges
Alarm keeps coming on and switches oven off
Switch oven on but the timer keeps going off and the oven stops working can't find manual
gwshaw71
  • 83 Answers
SOURCE: F2 code and alarm
here is a link to a referance of fault codes
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Hotpoint%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes
Posted on Dec 08, 2007
teeNjay
  • 5 Answers
SOURCE: WS-55909 Mitsubishi Big Screen TV timer keeps blinking
it must be recording soething have u got IQ?
Posted on Dec 30, 2008
  • 4 Answers
SOURCE: Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Posted on Jan 07, 2009
lastech
  • 408 Answers
SOURCE: Can't turn alarm off
hi,try your spare key
Posted on Apr 05, 2009
  • 4 Answers
SOURCE: Timex 250 Vac 25 Amp 24 Hour Timer Switch Won't Keep Time
Can the clock be repair or replace, my will not keep time.
Posted on May 23, 2009
AEG oven switches itself off after 35 mins
does it turn off after the oven has got upto temperature if it does it is probably that your thermostat has gone as this cuts off as a safety feature if your oven gets hotter than the thermo setting then it will shut off to protect from over heating or causing a fire hazzard with high temperature are you sure you havent changed the timer as well cus you can set a timer for your oven to switch on at certain time and to also switch off after a certain time if you still have the manuall have a look through the timer section if you do not have a manuall then check on your makers web site these should have a manuall online for you to check first i would check that the timer is not on if i can find you a manuall online i will post back hope this is some help.................
Nov 04, 2007 | Ovens
Turn off the alarm eaton viking stove
This did not work for me. The alarm won't go off at all. The dial for the clock seems very loose - it stuck many times when I was turning the dial to change the time, and then it just got loose, and now the alarm won't go off. Please help!
Jun 14, 2014 | Viking Stove/Oven/Range Timer Knob -...
Main oven doesn't come on
Check to see if one of the knobs on the timer has a "man" setting. This is for manual. Many times the clock will shut off the oven and moving the clock dial to man will close the switch in the clock to allow the oven to work. If it doesn't have this "man" setting check to see if there is a start and stop time. Make sure the start is out and the stop is pushed in.
Mar 23, 2014 | Ovens
My GE Profile Advantium Microwave Oven runs (and heats) continuously. The only way to stop it from running is to open the door.
Hi
Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 27, 2011 | GE SCB2001FSS Advantium Electric Single...
I purchased the Legrand RT1 Time Switch to run a bathroom fan. It is installed and I see indicator lights. Every time I turn the fan on, it runs for a second and stops (hearing clicking in the switch);...
You connected red and white wires together.
No problem, nothing burned out, and it's simple to fix. Steps below.
RT1 is electronic countdown timer, and electronic timer clock inside needs separate circuit, just like your alarm clock needs to be plugged in. >> that's why timer has white wire. White wire completes circuit to timer clock.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Heres what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push countdown button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 27, 2010 | Pass & Seymour / Legrand RT1-W 10-20-30-60...
Intermittently won't come on, now fails to work at all.
Your timer switch is going bad and will soon stop working alltogether. If the switch is a model DKJ/1-60 you will not find one, however, there is a switch made for Delonghi that will work. Go to The Gourmet Depot website and look for switch part # 05XDE5218104600. If you have a different switch look on smallapplianceparts.com for your part or search "small appliance parts" for a few other places that sell these parts.
May 16, 2010 | Oster 6295 Toaster Oven with Convection...
The blue light does not go on and the heating element does not wo
The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
My black and decker toaster oven is less than a year old and it has a burned out smell coming from it. I feel it might be a fire hazard and I am not comfortable using it anymore for fear of fire. What can...
Your problem is very likely the timer switch. They are very poorly made and they have a high failure rate. B&D should have a recall on these switches. It's likely a DKJ/1-60 timer switch. They make a very poor electrical contact which causes the switch and possibly the wall plug to overheat. Mine melted the wire insulation at the switch and failed. These switches are impossible to find fortunately because they are all subject to the same failure. There are a couple timer switches made for Delonghi ovens that will work in the B&D and other ovens that use the DKJ/1-60 timer switch. One is part # 5218104600 which works the same as the B&D switch but it only has about a 13 minute toast timer. Turn it counterCW to turn the oven on. There is another switch with a 120 minute timer which is part # 5218101800 but may be harder to find. The 13 min timer switch can be purchased for $10.98 at Gourmet Depot website. Another solution is to replace the bad switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts AC. You will no longer have a timer and you will need to turn the oven on and off manually but at least you will be able to use the oven and the switches are under $10 and much safer than timer switches.
Mar 06, 2010 | Black & Decker CTO649 Toaster Oven with...
Kitchen Ranges Logo
10 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
