Question about Pioneer AVH-P6500DVD Car DVD Player
Cannot recieve fm stations - Pioneer AVH-P6500DVD Car DVD Player
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
How to fix fm japan radio to recieve GCC fm signals ?
You can get a converter like this one.
http://catronics.com.au/fmconverter.html
It's a simple solution and it works.
Jan 18, 2011 | 1998 BMW 5 Series
Wont play radio whats wrong
Hook a piece of wire to the FM antenna input. You should get a strong station. Turn off FM mute. If you still can't get a station you will need reciever serviced.
Nov 22, 2009 | Emerson AV510 System
Reciever powers up and recieves signal (station and song titles are displayed) but doesn't transmit to car radio either through the assigned fm station or the aux cord.
IF you have a cord plugged into the audio jack, if will TURN OFF your FM transmitter. You have to leave it unplugged for the FM transmitter to work. Go to MENU and make sure your FM station is set and that the FM OUTput signal is turned up. Write back if you need more help.
Thanks,
John
Aug 19, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Factory radio recieves am stations only no fm stereo
get a new one as they are cheap these days!
& not worth the labour costs to try & fix them anymore!
Cheers Rob
Jul 20, 2009 | 2002 Chrysler Town & Country
1998 Wrangler Sahara - radio not recieving low freq FM Bands
if you are receiving stations on the higher frequencies then your radio is the problem and not your antenna or anything else
Jan 13, 2009 | 1998 Jeep Wrangler
No fm reception
look for a button called mode and press that, it should switch it to fm narrow (communications) or fm wide ( fm broadcast stations) or am
Aug 13, 2008 | Icom IC-R5 Handheld Scanner
Not recieving fm radio stations
if you can get am stations the problem is in the radio's tuner if you cannot get am stations either your antenna is bad, if this helps you please give me a good rating if not please e-mail me at merle840@aol.com
respectfully, m.merle
Apr 17, 2008 | Jensen CDH-1000 CD Player
Pioneer AVH-P6500DVD Car DVD Player Logo
18 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
