Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
Error belt cover erase process - Konica Minolta magicolor 1690MF All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
That is what is displayed on the control panel?
Posted on Jan 23, 2016
How can I correct this: process error-belt clear by cover,i need help????? on my Konica/Minolta 1690mf
I think this is mechanical problem and you need to check and remove belt-related assembly part.
Thanks
Sep 20, 2013 | Konica Minolta magicolor 1690MF All-In-One...
PROCESS ERROR-BELT CLEAR BY COVER
epson cx 16
May 16, 2012 | Epson ACULASER CX16
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Feb 27, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Printer will not print showing error 2200. How do l fix it?
This is a scanner error. You could try the following...
Power off and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off and remove the power supply from the back of the unit.
Open the top cover
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Nov 15, 2010 | Lexmark P6250 All-In-One InkJet Photo...
Why do i always get a jum error 523 when i swich on my blackberry 8700g
Hi, To resolve this issue, first perform a hard reset. For instructions
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If this does not resolve the issue, the BlackBerry Device Software must be re-installed
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager
1) Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
2) Click Next.
3) Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
4) Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
5) Click Next > Finish. .
I hope this information will help you
Nov 22, 2009 | RIM BlackBerry 7290
SVC EL ERROR appears on the display
The SVC EL error on the 8008 indicates an 'ERASE LAMP' error.
The erase lamp in the 8008 is situated below the OPC belt in the printer, as a step to fixing the problem I would suggest removing the OPC belt from the printer, and taking suitable precautions to protect it from light and damage.
Then clean the area under the OPC belt in the printer to remove any stray toner.
Then test the printer, if the problem persists I would recommend having a suitably qualified engineer look at the printer. To check the Erase LED array is connected correctly and is functioning correctly.
Jun 21, 2009 | TallyGenicom 8008 Laser Printer
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
49 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
