Question about Video Game Consoles & Games
Need two hal's hole in one golf manuals - Video Game Consoles & Games
How long does it take to play a round of Golf?
On average, a round of golf is expected to take about four hours to play for a group of four golfers. The length of time to play 18 holes may varies due to many reasons. Visit Lee Valley Golf & Country Club for best Golf Courses in Cork Happy Golfing!!
Jun 25, 2016 | Cars & Trucks
Can a golf ball be replace by a different type of ball during tournement play
"There is nothing in the Rules of Golf that prevents a golfer from switching to a different brand of golf ball (i.e., from a Titleist to a Bridgestone) on every hole on the course - so long as the change is made between the play of holes.
However, there is something in the Rules of Golf that says a tournament committee can impose such a rule.
It's called the "one ball condition" (in the rulebook, it's in Appendix 1, Part C), more commonly known as the "one ball rule." As you probably know, all Tour events are played under the "one ball rule." And any rules committee may adopt the "one ball rule" for its competitions.
"The "one ball condition" requires the player to use the exact same brand and type of ball throughout the round. For example, if you tee off the first hole with a Titleist Pro V1x, then that's what you must play throughout the round. You may not switch to any other brand of ball, nor even to any other type of Titleist ball. You started with the Pro V1x, so the Pro V1x is what you must use on every stroke. "If the "one ball rule" is not in effect, however, golfers may swap out different types of golf balls at any point in a round of golf, so long as the change is made between holes rather than during the play of a hole."
Aug 25, 2014 | Golf
APROBLEM HAS BEEN DETECTED AND WINDOWS HAS BEEN SHUT DOWN TO PREVENT DAMAGE TO YOUR COMPUTER
While you may not be using a Windows 2000 computer, the error/cause is probably similar: http://support.microsoft.com/kb/256841
Try to manually install the Standard PC hardware abstraction layer (HAL):
  1. Reboot the computer to restart Setup.
  2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
Nov 10, 2011 | E-Machines eMachines Desktop PC
Golf logix 8
it should change by itself.
May 11, 2010 | Garmin Golf Logix GPS
Hi, my golf boot wont lock with the key
You will need to remove the lock cylinder mechanism and take it to a locksmith to remove whatever is jammed into the key slot. While the cylinder is out, check the operation of the remote release.
Dec 23, 2009 | 1999 Volkswagen Golf
How do I remove the ignition switch?
i had to do this once, you actually have to drill a small hole near the ignition switch to press a hidden button. i would strongly suggest getting the manual for that job. so you don't drill the wrong place.
Nov 19, 2009 | 1991 Volkswagen Golf
Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Jul 17, 2009 | 1995 Volkswagen Golf
Video Game Consoles & Games Logo
544 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
