Question about Saitek Pro Flight Yoke System Flight Simulator
I have no throttle power in fsx using saitek pro flight controller how can i fix it?
5 Suggested Answers
rh10
  • 122 Answers
SOURCE: saitek pro flight yoke problem
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
Posted on Jul 12, 2010
rh10
  • 122 Answers
SOURCE: I have two saitek pro flight throttle quadrants
To get the quadrants to operate four throttles, you need to assign AXIS not buttons, then you will be able to set them up.
rh10
  • 122 Answers
SOURCE: Using Pro Flight Yoke, etc. in fsx
To keep the settings in FSX you must got to the main page, choose settings, create your settings then save the configuration file with a name, ie "myconfig.cfg" or something you will recognise,
Don't try to do the settings from within the game from the top menus as they are not saved this way. Exit the game back to the start screen and do your settings from there, This will fix it. Good luck.
Posted on Jul 13, 2010
rh10
  • 122 Answers
SOURCE: Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Posted on Jul 16, 2010
In FSX (Win7 64bit) couldn't get enough speed to take off! Found that when Saitek proflight quadrant set at max only around 85% power delivered. Had to use mouse pointer in virtual cockpit to advance...
Hi Alf,
This sounds like a deadzone setting not allowing the throttle axis to go full.
There are 2 places in which the deadzones can be set:
In FSX: Settings> Controls> Calibration, there select your Yoke and then set the NULL to the left, which is 0.
Or in windows in Input Devices (Win Xp - is in Control Panel, Vista or Win7 go to Games Explorer>Tools>Input Devices).
In Input Devices->Select the Yoke and click Properties, then go to the Deadzones Tab and set the deadzones for the Throttle. Mixture and Prop to 0.
Hope it helps...
Apr 29, 2011 | Saitek Pro Flight Yoke System Flight...
I have a Saitek Pro Flight Yoke System with Throttle Quad and it works fantastic with MS FSX, but if I try to use it with my Proflight, as soon as it starts, it does a wild left hand turn and just gets...
Try to get the latest drivers from www.saitek.com
Try it on another computer and if it does the same there too you might want to consider that it can be faulty...and you might want to request a replacement for it.
Hope it helps..
Apr 24, 2011 | Saitek Pro Flight Yoke System Flight...
Bought the saitek headset how do configure to talk to the tower in the fsx game
You cannot talk to the tower in FSX, only via third part software and then the button you wish to use would be configured within that software (such as Live ATC),
May 15, 2010 | Saitek Pro Flight Yoke System Flight...
On saitek yoke system it wont work on fsx *flight simulator x* if you can help thanks !!!!!!!!!!!!!!!!!!!!!!!
Ensure you have installed the drivers for it. If you don't have them, go to Saitek web site, download and install the correct one's for your operating system. Also ensure that the yoke is plugged into the USB port on the rear of the PC as these USB sockets give the most power. Additionally, you have to set the yoke up in FSX\Settings so it knows what to do with it with regard to calibrating it and assigning what buttons do what.
Sep 07, 2009 | Saitek Pro Flight Yoke System Flight...
SPOT VIEW FIXED
You need to assign what view you want to the cooley hat on your controller in FSX\Settings. Rethe Zoom, press the backspace key to reset it, then use the + and - keys to zoom in and out.
Apr 22, 2009 | Saitek Pro Flight Yoke System Flight...
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Jun 02, 2008 | Saitek (PS28) Joystick, Throttle
Saitek Pro Flight Yoke System Flight Simulator Logo
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
