Question about Viking Microwave Ovens
Microwave does not go on
Nothing goes on
Nothing happens when plugged in
The main fuse in the microwave oven has probably blown, it usually goes when a part has failed.
May 07, 2012 | GE SpaceMaker Microwave Ovens
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
The dial on our GE JVM1790WK01 microwave turns freely but does nothing. I checked the knob for damage, none found and the shaft turns freely with a slight bump as it goes around, but does nothing.
turntable problem? it's probably the motor itself. it's easily removed under the bottom panel. you'll need the pricey ge orig. part; as they use a odd 21volt motor. good luck.
Aug 06, 2011 | GE JVM1790 1000 Watts Convection /...
Clock, timer ,key board work ..but set time and it counts down but nothing goes no turntable or heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Mar 20, 2011 | GE JES1290 Convection/Microwave Oven
The microwave seems to be stuck on delay
thats what the express does its a one button start it
there s nothing wrong with the unit it is doing exactly what is programmed for what you are pushing
Oct 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat. turntable works control
Hi! check the fuse that goes through the magnetron because i think it is no functioning.
Sep 10, 2009 | General Electric Microwave Oven
My microwave does everthing but heat- timer counts down, but nothing goes on inside.
Microwave Oven Basic Troubleshooting Tips
heatman101
dygwr
Jul 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Microwaved a sandwich from Wendy's-apparantly it had tinfoil wrap
There is fuse in the back somewhere around where the cord comes into the unit.My guess the fuse is blown
Mar 15, 2009 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
