Question about IBM Infoprint 1412 Laser Printer
No paper jam,but light will not go off
Paper Jam light is on and we can not print. there is no paper jam, we have tried rebooting, powering off and on. What else can we do?
SOURCE: IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Posted on Apr 17, 2009
SOURCE: 202 Paper Jam
A 202 error usually means that there is a problem with the fuser, more than likely the fuser exit sensor is jammed - either with a piece of paper, or the return spring on the sensor has stuck. Check this sensor, making sure it can return to the upright position freely. This should clear the problem. If it doesn't, or the sensor arm is broken, a new fuser should solve this problem
Posted on Jul 17, 2009
  • 226 Answers
SOURCE: 933.00 Service Printhead Error
take the toner out and shake it or try to replace it with a new one
Posted on Jul 21, 2009
NoelmWaite
SOURCE: my printer is saying tray 1 paper jam but there is
I'm not sure how to fix it yet but I have two of these printers and if I use the tray from my other printer it works. I'm not sure what's wrong with the tray but it is the tray for sure.
Posted on Jul 28, 2009
  • 1684 Answers
SOURCE: paper jam 241.10
The 241.10 error indicates 2 possible problems. First is worn pickup rollers, you said that you flipped them. that should have temporarily fixed the issue. The second option is overfilling the paper tray, try it only half way full and see if it picks up paper and prints. If it still does not pick up paper I would replace the pickup rollers, the turning them inside out trick is only temporary anyway. The roller surface should be rough and have a texture to if not smooth at all. We have the roller kit available if you need one, they run $8.95 shipped. Contact us at the email below if you have any questions or if you need a set of rollers.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 09, 2009
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Canon mx410 paper jam error
For me on my Cannon MX410 with a "paper Jam" light displayed this WORKED!! The absolute BIZZARE thing was after I went and through the described procedure above and rebooted and tried to print the 1st page that came out had a "crushed" ****-roach on the 1st page! So I didn't have a paper jam,...but a
ROACH Jam. :) I told my wife, Humm pest service not workin I guess! It errored out again, but simply unpluggingUSB and power cord (not the steps described for the Print Spooler) it prints fine. SO saved me buying a new printer which was just 6 mos. OLD and FINE by me! So THX, Vikram Kumar Thumu!
Jan 28, 2012 | Canon Pixma MX410 All-In-One Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Was printing 14 page document from internet then got message to clear paper jam. I cleared paper jam and now when I try to print page 2 a blank page comes out
You will have to reset the printer, Unplug from wall, unplug from PC, reboot, Now, plug in Power to printer, & plug in USB on PC, reboot. When at desktop next, well, now try printing again.
Feb 17, 2010 | Office Equipment & Supplies
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Both power light and paper jam light on
clear the paper jam. take out the paper(if any) from back of the printer. Clear all prints in que and try to print
Aug 13, 2008 | HP DeskJet 970cxi InkJet Printer
IBM Infoprint 1412 Laser Printer Logo
35 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
