Question about Heavy Machinery
Engaging 4x4 in 98 ranger - Heavy Machinery
1992 FORD RANGER AUTOMATIC TRANSMISSION WILL NOT SHIFT INTO GEAR
check your brake pedal push down see if your brake lights are coming on if they are not check the switch at your brake pedal that also let you engage tranny into gears
Feb 17, 2013 | 1992 Ford Ranger
Ford ranger 4wd will not engage
Try backing up and forward moving slowly, sounds like its trying to engage
Feb 09, 2013 | 1998 Ford Ranger SuperCab
1983 ford ranger transfer case engages but the wheel will not engage
you may have lock outs on your wheels these need to be engaged manually
Jul 07, 2012 | 1983 Ford Ranger
1992 Ford Ranger 4.0L; I push the 4x4 button, as you drive there is a bang sound from the front end, sounds like the drivers side where the noise is coming from, Under no load not so noticeable. Universals...
Is the 4x4 an Auto Engage? If not you must be STOPPED and in NEUTRAL to activate your 4x4. Being a 1992 Ranger I am going to guess it is NOT Auto Engage, therefore you must be stopped and in neutral.
Hope this helps.
Sep 09, 2011 | 1992 Ford Ranger
Not a problem as much as an answer. Are both wheels rear wheels engaged at all times on my 4x4 87 ranger?
this is a rear wheel drive vehicle and as such the rear wheels are always engaged.when in 4 wheel drive the transfer case in gages and the front differential connects and is engaged.unless the 4 wheel drive is engaged the transfer case just free wheels.
Apr 27, 2011 | 1987 Ford Ranger
My 1998 Ranger 4 wheel drive trouble.
if you have auto lock hubs,one of them is faulty,you can replace these at Autozone,
if you could have the front wheels off the ground you could tell which side is not engaging
Dec 09, 2009 | 1998 Ford Ranger SuperCab
4 Wheel doesn't engage on 99 Ford Ranger
if you have locking hubs then yes. They could have been put together wrong. But if non locking then have it inspected to be sure nothing is off. It should be easy to find if something was left off.
Nov 17, 2009 | 1999 Ford Ranger SuperCab
1999 ford ranger 4x4 wont engage
ck frt drive shaft out of trans-fer case is turning if it is ck both hubs on outside of axles auto locking hubs have alot of problems
May 30, 2009 | 1999 Ford Ranger SuperCab
Heavy Machinery Logo
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
