Question about As Seen On TV Soap Magic Hands Free Soap Dispenser
Soap magic dispenses on its own
Dispenses on its own
Soap does not despence
I have never come across any refrigerator that dispenses soap. Water and ice, but never soap. Make and model please?
Sep 25, 2017 | Refrigerators
My Hayden automatic soap dispenser dispenses soap when I turn the lights off in the bathroom.
auto eye in unit senses someone putting their hand under it
Sep 15, 2017 | Home
My flow indicator won"t spin but water dispenses
Check the belt on the soap pump. Water may be dispensing but soap is not mixing with it when the indicator is not spinning.
Feb 11, 2015 | bissell"" pro heat 2x select upright deep...
Soap no longer dispenses automatically.
Mine would not work with the Costco brand (Kirkland) batteries. The light indicator came on but the pump did not work. Once I replaced them with Durcell, the pump started working. I'm guessing Energizer brand would work just as good.
Nov 22, 2013 | Umbra Otto Automatic Soap Dispenser,...
F7210-900 Steam Vac. will not put out water when switch is in wash position but it will put out water when the rinse position
There are two electrical solenoids inside the hood assembly. One opens to dispense rinse water, and the other dispenses the soap and water solution. It is likely that the soap and water solenoid has failed and will require replacement. A "work around" fix for this is to mix the soap solution in the clear water tank ( 5 oz. of shampoo per gallon of water ), and shampoo that way until the solenoid can be replaced.
Mar 15, 2011 | Hoover Vacuums
My simple human sensor Soap Dispensor will not
Hi, you have this question in the wrong park of the site. But I did a quick google search and believe I may have found an answer for you. I'll copy and past what I found for you here. If this doesn't solve the issue you should probably repost this question
"In the spot where the soap dispenses, there is a very small plug which controls the flow which you need to gently pull out and release (not break off) in order to break the vacuum seal. This information is not included in the regular instructions, but rather is written on a small 2-inch square piece of paper in the box. I was getting very frustrated because I had "primed" the soap dispenser at least 30 times and nothing had come out. I noticed the small plug, and while looking through the box again found the small piece of paper with the additional instruction. After that, it worked great! I use a generic version of Soft Soap, and we find the lowest setting dispenses more than enough soap."
Mar 04, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Hotpoint wma46, my machine does't seem to be taking/emptying the condition during the cycle, i have taken the draw out and cleaned it but it still won't work properly any advice ??
Hotpoint wma46 This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question
Jul 08, 2009 | Hotpoint WMA46 Front Load Washer
Whirpool washer fabric softener container
i would quit using powder soap and use the HE soap.I would take the soap dispenser out and clean it out and also clean out behind the dispenser.run just water thru machine or try washer magic to clean out the machine.you can find washer magic at most home depots or lowes or even a appliance parts house.
Mar 08, 2009 | Whirlpool AWM8143 Front Load Washer
As Seen On TV Soap Magic Hands Free Soap Dispenser Logo
Top As Seen On TV Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an As Seen On TV Radio Communication Expert? Answer questions, earn points and help others
