Question about Athearn HO RTR 53 Wabash Duraplate Trailer, Dart Adv#2(2)
BEARING NUT TORQUE ON WABASH SUSPINSION - Athearn HO RTR 53 Wabash Duraplate Trailer, Dart Adv#2(2)
How do I rgerplabe how do I replace a front wheel bearing?
TO REMOVE FRONT WHEEL BEARING.YOU NEED TO SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS.MAKE SURE SITTING ON LEVEL SOLID GROUND.BEFORE RAISING VECHICLE OFF GROUND YOU NEED TO LOOSEN HALF SHAFT AXLE NUT JUST A LITTLE BECAUSE WHEEL IN THE AIR HARD TO LOOSEN AXLE NUT WHEN YOU HAVE HOLD THE WHEEL WHILE LOOSEN THE AXLE NUT WHICH IS TORQUE ON ABOUT 200 FT LBS.USING A SIX POINT AXLE SOCKET SOCKET SIZE COULD BE 34 OR 35 METRIC 1/2 INCH SOCKET.YOU NEED 1/2 INCH BREAKER BAR.ONCE YOU LOOSEN AXLE NUT A LITTLE THEN RAISE VECHICLE THEN REMOVE WHEEL.THEN FINISHING REMOVING AXLE NUT AND WASHER.THEN REMOVE THE CALIPER FROM THE STEERING KNUCKLE AND SUPPORT IT ASIDE USING A PIECE OF WIRE.REMOVE BRAKE ROTOR.THEN REMOVE THE 3 HUB BEARING ASSEMBLY BOLTS. USE A SWIVEL SOCKET GOING TO BE HARD TO REACH SPOT WITH A REGULAR SOCKET. REMOVE THE HALF SHAFT FROM THE HUB BEARING ASSEMBLY.REMOVE HUB AND BEARING ASSEMBLY. PUT EVERY THING BACK VISA VERSA. TORQUE HUB BEARING BOLTS TO 70 FT LBS. TORQUE AXLE NUT 284 FT LBS IF YOUR CAR IS 1998 MODEL AND TORQUE AXLE NUT 100 FT LBS FOR THE 1999 TO 2001 MODELS.THE WHEEL HAS TO BE ON THE GROUND JUST ENOUGH TO KEEP IT FROM TURNING.DONT LET ALL THE CAR WEIGHT DOWN UNTIL YOU HAVE TORQUE WHEEL TO THE RIGHT TORQUE.LET ME KNOW IF YOU HAVE ANY PROBLEMS.
Mar 21, 2011 | 1999 Oldsmobile Alero
I need the torque specs on a rear axle pinion nut for a 2003 Dodge Ram 2500 4/4 Cummins, Automatic.
The pinion nut does not have a torque spec. as in how tight the nut is. The amount of torque is measured in bearing preload. You will need a "torque to rotate" torque wrench. If you are using new bearings the torque spec. is 15-25 in. lbs. If you are using your old bearings the torque spec. is 10-20 in. lbs to rotate. To measure this you will need to tighten the nut in small increments then use the torque to rotate wrench to turn the pinion without the carrier/ ring gear installed. Repeat until desired torque is reached.
Jan 29, 2011 | Dodge Ram 2500 Cars & Trucks
Procedure for replacing rear whl brgs on a 2003 escape awd
4-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Rear wheel
    • Rear brake shoes
    • Rear halfshaft nut and loosen the halfshaft from the hub
    • Wheel hub and place it in a vise
    • Inner wheel bearing race from the hub
    • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
    • Parking brake cable from the steering knuckle
    • Brake line from the wheel cylinder and support the knuckle
    • Lower shock absorber nut
    • Lower ball joint by holding the ball joint stud
    • Upper ball joint
    • Coil spring while noting the location of the insulator
    • Steering knuckle cam
    • Steering knuckle
    • Snapring and press out the outer wheel bearing race from the knuckle
      Rear hub and bearing
      Click to Enlarge
To install:
  1. Install or connect the following:
    • New wheel bearing into the steering knuckle
    • Snapring to the knuckle
    • Wheel hub
    • Steering knuckle cam and hand tighten the bolt
    • Coil spring
    • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
    • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
    • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
    • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
    • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
    • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
    • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake shoes
    • Rear wheel
  2. Fill and bleed the brake system.
  3. Check and adjust the wheel alignment as needed.
2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
    • Wheel bearing outer race from the knuckle
      Rear hub removal
      Inner wheel bearing removal-rear hub/bearing
      Rear wheel bearing removal-2wd
      Rear wheel bearing removal-4wd
To install:
  • Wheel bearing in to the knuckle
  • Snapring
  • Wheel hub into the wheel bearing
  • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
  • Brake drum
  • Rear wheel
    Rear wheel bearing installation
    hope this helps if so send testimonial comment or even any other questions you have
Jan 16, 2011 | Ford Escape Cars & Trucks
TORQUE SETTING ON FRONT WHEEL BEARING NUT ON 2006 PONTIAC TORRENT
Hello, here is the torque spec for front hub bearing
Strut to Steering Knuckle Bolt and Nut
180 N·m
133 lb ft
Tie Rod Retention Nut
50 N·m
37 lb ft
Wheel Bearing/Hub Mounting Bolt
130 N·m
96 lb ft
Wheel Drive Shaft Spindle Nut
205 N·m
157 lb ft
Nov 07, 2010 | 2006 Pontiac Torrent
Replaced rear axle pinion bearing and seal, need to know pinion nut torque spec. for aam rear axle 2005 dodge 3500 4x4 Thanks.
There is no torque specs,this nut has to be tightened back like it was ,the best thing to do,was,to late now,is to use a torque wrench to remove the nut,and remember the torque,and when replacing it,torque it back to that spec,the reason being,there is a crush sleeve between the front pion bearing ,and the rear pinion bearing,and it has to be crushed to a certain amount,to aquire deepness into the ring gear,anyway just give it about 25 lbs torque,any more the crush sleeve will crush even more and the deepness of the pinion will be too much.
Apr 19, 2010 | 2005 Dodge Ram
Front wheel bearing assembly unit, what tools will i need? size sockets ext the right foot lbs of torque for the axel nut,
TOOLS YOU NEED IS 35 METRIC SOCKET FOR AXLE NUT.USE 6 POINT SOCKET.DONT USE 12 POINT SOCKET.COULD DAMAGE AXLE BOLT EDGES.MAKING IT HARD TO GET OFF.YOU NEED A TORQUE WRENCH WITH THE RANGE OF 200 FT LBS TORQUE.YOU NEED 1/2 BREAK BAR.AND A HUB PULLER.NOW TO LOOSEN AXLE NUT.BEST TO LEAVE TIRE ON WITH CAR WEIGHT ON GROUND TO LOOSEN THE AXLE.BECAUSE ITS GOT 192 FT LBS TORQUE.HARD TO LOOSEN WITH TIRE OFF.192 FT LBS TORQUE IS WHAT YOU TORQUE IT AT.BESURE TO READ INSTRUCTIONS TO NEW HUB BEARING ASSEMBLY. YOUR AXLE NUT TORQUE WILL BE DIFFERENT IF YOU GET A NEW GREY NUT.BECAUSE NUT STRENGHT WILL BE DIFFERENT.IF YOU GET A BLACK NUT WHICH IS HARDER STEEL TORQUE WILL BE 192 FT LBS.YOU NEED A 13 METRIC SWIVEL SOCKET TO GET HUB BEARING BOLTS OFF THEY WILL BE IMPOSSIBLE TO REACH WITH OUT IT.HUB BEARING BOLTS TORQUE IS 62 FT LBS
Mar 16, 2010 | 1999 Oldsmobile Alero
I need the torque specs for the main and rod bolt for a 99 escort 2.0l engine
engine tightening torques
Main bearings Renew bolts/nuts No
Main bearings Stage 1 43 Nm
Main bearings Stage 2 85 Nm
Big end bearings Renew bolts/nuts Yes
Big end bearings Stage 1 15 Nm
Big end bearings Stage 2 90°
Jan 21, 2010 | 2004 Ford Focus
Front Hub Bearing Torque specs to complete replacement
THE LUG NUT TORQUE SPEC - 140FT/LBS\
CALIPER MOUNT - 80FT/LBS
CALIPER BRACKET 129FT/LBS
AXLE NUT 177FT/LBS
Apr 24, 2009 | 2003 Chevrolet Silverado 1500
99 dodge intrepid specs
Inner main bearing cap bolts:
Torque to 15 ft-lbs, then rotate an additional 1/4 turn
Outer main (windage tray) bearing cap bolts:
Torque to 20 ft-lbs, then rotate an additional 1/4 turn
Main bearing cap cross bolts:
Torque to 250 in-lbs or 20.83 ft-lbs
Connecting road bearing cap nuts:
Apr 21, 2009 | 1999 Dodge Intrepid
Athearn HO RTR 53 Wabash Duraplate Trailer, Dart Adv#2(2) Logo
19 people viewed this question
Top Athearn Toys Experts
Jay Finke
Jay Finke
Shehu Pro
Shehu Pro
Are you an Athearn Toy Expert? Answer questions, earn points and help others
