Question about Amana Refrigerators
Freezer on model TRG22JL wont work
Since vacuuming underneath the refrigerator the freezer will not get cold enough. Did I bump something?
  • 2318 Answers
SOURCE: kenmore elite refrigerator
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
Posted on Jul 08, 2008
22yooper
  • 828 Answers
SOURCE: frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Posted on Sep 15, 2008
  • 19 Answers
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Posted on Apr 22, 2009
heatman101
  • 43501 Answers
SOURCE: freezer works refrigerator does not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
SOURCE: refrigerator not cooling freezer not cold
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead? If so, see “It's stopped completely.”
Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
Cooling is poor
For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
The defrost timer
The defrost thermostat (also called the bi-metal switch)
The defrost heater
to check these components .... please refer to my solution in the below link....
http://www.fixya.com/support/t4189238-defroster_not_working_checked_defrost
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
If I've been of Help to you... kindly take a moment to rate this solution.
Posted on Sep 10, 2010
Why is my frt18s6awx not getting cold enough in freezer & fridge?
Good Afternoon Friend,
I understand that your Frigidaire freezer, model# FRT18S6AWX, is not getting cold enough in either the freezer or refrigerator. I suggest changing the settings to a colder setting and give it 24 hours to stabilize at the set temperatures. Also, I recommend cleaning the toe grille and condenser coils. You can do this by taking the toe grille off and cleaning it with soap and water and rinsing it thoroughly with water. While the toe grille is off, get your vacuum with extension, and vacuum underneath your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRT18S6AW Top Freezer...
Refridgerator and freezer not cold enough. Food is thawing and not staying cold enough. Fan is working. not making any weird sounds. No frost build up in back. Vacuumed and wiped down condensor.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 20, 2011 | GE GSL22JFPBS Side by Side Refrigerator
Freezer is cold, refrigerator is not cold, also not cold enough for making Ice
See if the condenser fan motor underneath is running.Maybe completely filthy with dust build-up underneath refrigerator.May need to rake the coil.
Feb 07, 2011 | Kenmore Refrigerators
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Bottom of refrigerator not getting cold enough, freezer is working fine, - Magic Chef -model MCBR1000w
have you cleaned out the coils underneath the fridge? it's very simple. pull the fridge out, look underneath(try pulling off the bottom grill from the front for more access), and start cleaning. to much dust and lint will hinder the coils from cooling. A vacuum with the brush attachment or little broom works good.
Jul 27, 2009 | Magic Chef Refrigerators
Whirlpool ED5PHAXSB side by side refrigerator not cooling...
There are a lot of possibilitys. You'll have to use the process of elimination.
But it could be the thermostat (make sure your setting is midway) The milk spoiling indicates it is too warm so bacteria is breeding
Get a refrigerator / freezer stand alone thermostat (about $5) That will give you accurate readings. The fridge shoud be between 35 and 40 F and the freezer 0 plus or minus 3 when set correctly
It could be your condensor fan is clogged or just that your coils need cleaning (underneath or behind) Use a vacuum with the brush end or chisel point. Dust can cut you efficiency by 20 or 30% by itself.
Assuming this is frost free model the defrost timer may be acting up in the freezer.
Forgive me for not knowing where the coils are and if it is frost free but I can't find a manual for this particular model. However the principles apply in any case.
May 09, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Refrigerators Logo
24 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
