Question about Brother MFC Office Equipment & Supplies
Brother MCF-9130CW manual feeder does not pull paper in. Message tells to load paper, but does not detect it when you put it in.
When it was working properly, when you put the paper/envelope in, it used to grab the paper and pull it in a little. Now, when it calls for paper to be loaded and you put it in, it does nothing and is still calling for paper. It does not seem to sense that you have loaded the paper/envelope.
SOURCE: Envelope printing
Got a 3100CN and had the same problem but found that a) Changing paper size from the web doesn't work but b) Go to the printer control panel on the printer and use the menu to set the paper size for the MPF tray for FREE. Now your application under windows will overide the whatever the printer thinks and will print. Envelope via Word all work without problem. Suggestion . Configure two printers one B&W using tray one and one colour using MPF and you can now quickly select whether to use colour or b&w. Regards John N - N2UYI/G7LTQ
Posted on Jun 02, 2007
SOURCE: Brother MFC 8840, Document Feeder is not workting
ITS PROBABLE THAT A CONNECTOR CAME OUT.REMOVE BACK CORNER PANEL AT FEEDER CABLE TO CONFIRM.
Posted on Sep 11, 2008
  • 105 Answers
SOURCE: document feeder appears broken in my HP officejet 7310
I'm sure this will solve your issue.
all the best.
Posted on Oct 05, 2008
Corysf62
  • 188 Answers
SOURCE: Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Posted on Nov 22, 2008
Testimonial: "Absolutely useful although I didn't see it when I worked it out by my own."
SOURCE: Paper "grabber" won't grab
Sounds very similar to my problem. In my case the Feed Switch ( Button on front console) got changed to load from the front tray, although paper was in back. I hit feed switch and changed to rear tray. Now it loaded and printed.
Posted on Dec 02, 2009
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
I get the message that says "no paper in auto
Not sure if you get this message on the machine or in the software on you PC. It could be a software setting if it's on the PC that tells it where to pull the docs from. If it's a scanner message it could be an object blocking the paper sensor telling it something is in the feeder. Check the feeder paper path for anything that does not belong there or carefully blow out the paper path with compressed air. Sometime dust collection does this.
Feb 03, 2011 | Xerox DOCUMATE 510 Flatbed Scanner
Brother printer will not print because I keep getting manual feed
thios means the job you sent to print was detected as a differant size then the paper in the tray.
you would have to put a page in the front slot of the machine until it clears out this job
Mar 24, 2010 | Brother HL-4050CDN Printer
Brother DCP8040 does not recognize paper in the ADF.
document feeders have a small actuator that tells the copier there is paper in the feeder, sometime they can get knocked out of place and do not detect the paper...check for the actuator that senses the paper....
Dec 29, 2009 | Brother Office Equipment & Supplies
Document Feeder won't work
hello! check and look to see if there is anything blocking the paper feed area, if all is good, get some denatured alcahol and clean the paper feed roller as it may have a build up of paper dust good luck brother sr tech
Jan 14, 2009 | Brother MFC-8460N All-In-One Printer
Load MP Feeder
That is not an error message. it is telling you to load the Manual Paper feeder. Put some papaer in it and it will print. check youyr set up to make sure that you are printing to the trays not the manual feeder
Nov 20, 2008 | Lexmark Optra M412 Laser Printer
Lexmark T644 MP Feeder STOP ASKING FOR MP FEEDER???!!!
Thanks mate, it worked for me too and my works printers (work in IT and this 'error' was driving us crazy)
Jul 29, 2008 | Lexmark T644 Laser Printer
49 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
