Question about Whirlpool Dishwashers
Dishwasher not sanitizing
I had trouble with dishwasher not completing the entire cycle. First I replaced the controller Cntrl-ElecOEM that helped, but then it didnt complete the drying cycle. So then I replaced the heating element. Now its not sanitizing completing the sanitizing cycle the sani light flashes at end of cycle. So it not going to the heat it needs to sanitize. Can anyone help me?
3 Suggested Answers
KOakaKO
  • 135 Answers
SOURCE: Two Green Lights Flash Mid Cycle.
It's possible that there's a fault in the drying heater coil, but I couldn't tell you for sure without looking up your machine. If you could locate the model number tag on your machine and write down the exact model number and serial number, then I could likely give you a more informative answer. ;)
Posted on Aug 10, 2007
  • 120 Answers
SOURCE: my dishwasher has the sanitize option but at the
Check your owners manual to see when the light should come on. If it comes on due to high temps, then the heater element may be bad. Run it, then see if element is hot (be careful !)
Posted on Oct 02, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Dishwasher will not go thru full cycle
Hello friend, thank you for your post!
Based off the information you provided your Frigidaire dishwasher will not complete a full cycle. It sounds like it could be an issue with the control panel or door switch. When your dishwasher stops working does it display an error code or do a series of lights flash? I would recommend performing a reset on your appliance which can be done by disconnecting power from your dishwasher by either unplugging it or flipping the household circuit breaker. Hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire Dishwashers
Control panel stopped working, no lights
The most common problem on washing machines and dishwasher is failure of the electronics, usually the circuit board. As you have already had a problem (sanitize cycle) I am afraid it sounds like you need to call an engineer. Replacing the electronics will be expensive, but it may be loose connections only. :(
Jan 11, 2014 | KitchenAid 24 in. KUDS02FRSS Stainless...
My Frigidaire dishwasher - most buttons don't work and clean and sanitized lights are flashing after cycle completes.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
Sep 23, 2012 | Frigidaire Dishwashers
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
My dishwasher is installed, but it won't go past the "washing" cycle. I have very hot water and am not using the "sanitize" option. Any ideas what could be causing this?
Your Question:
"My dishwasher is installed, but it won\'t go past the "washing" cycle. I have very hot water and am not using the "sanitize" option. Any ideas what could be causing this? "
Hi, I have ideas about your dishwasher. It apparently has a failed timer.
If this is a new dishwasher installation of a new machine. Then it is defective and is covered under the manufacturer's warranty.
The hot water issue is fine. A dishwasher's internal water temperature should be at least 140 degrees, so the machine will heat up water to accomplish this.
I would cancel the cycle the machine is in test it in various cycles.
I would try it in sanitize as well. If it completes the full cycle. Then use it.
However, if it hangs up again. I will need a new timer mechanism.
Hope this helps. If you have any questions at all, reply to me through this website.
Best Regards,
Mark
Jan 22, 2011 | Frigidaire Professional Series 24 in....
There is a smell in the dishwasher and on the dishes when clean
I suspect stagnant water is laying in the bottom areas. You will have to lay the machine on it's back to access the pump.
May 27, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
