Question about Hotpoint Aquarius WMA42 Front Load Washer
Washing machine over fills and says no water supply
After it says no water supply it says F5 Error but will drain fine when error shows
  • 1294 Answers
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Posted on Sep 03, 2007
jason0110
  • 66 Answers
SOURCE: error code h20
hi sounds like a faulty fill valve easy fix
Posted on Sep 21, 2008
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
57 varieties
  • 1653 Answers
SOURCE: Hotpoint WF840 W machine still full of water error code F 05.
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
  • 197 Answers
SOURCE: Hi I have a hotpoint washing machine model wt761
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Posted on Oct 25, 2009
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Have samsung sw5ousp 5kg it is showing 4e water error any help b great thanx in advance
    The Error indicates that the water level did not increase or fill in time to the machines estimation . 4E WATER SUPPLY ERROR Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON. Check that the water valves are fully open check that any fill lines that have washer hose filters in them are clean check you source water pressure is OK
    Apr 18, 2016 | Samsung Washing Machines
    How do I fix error code E21 on Electrolux Front loader washing machine?
    It is the customer fault code. Simply turn on and turn off appliance.
    E11 - problem with fill water
    E21 - problem with draining water
    E41 - door open
    All other errors require service staff !!!
    Sep 13, 2014 | Electrolux Washing Machines
    My front loading Crosley washing machine is showing error code 21. What does that code mean?
    Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
    Jun 23, 2014 | Crosley CW5000 Front Load Washer
    Hi, have a problem with my hotpoint wfm940 washing machine. It had an error f5 which relates to the drum not draining, found rubber bands in the pump. Machine isn't running any cycles now, it will spin,...
    Try removing the plug or switching off the washing machine and leave it for about ten minutes. Hopefully this will reset the electronics and allow normal operation again..
    Jan 02, 2014 | Washing Machines
    E9 E2 ERROR
    Message = E2
    Error = OVERFLOW ERROR
    Cause & Solution =
    The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
    The valve inlet is normal, but the water level sensor Change the water level sensor
    (sensor pressure) is low. (sensor pressure).
    The drain motor does not work - Test and if faulty change the drain pump
    Message = E9
    Error = SENSOR PRESSURE ERROR
    Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
    Mar 10, 2012 | Daewoo Washing Machines
    SAMSUNG J1253 ERROR CODE 4E
    Did you leave out the complete model number?, If you haven't yet check your water supply, If you changed to or have the auto stop flood hoses some washers cause them to activate.
    The wires may be disconnected on the water valve(s) or a valve went bad or the main board went bad, You can use a meter to check that there is voltage going to the valve(s) when you start a fill cycle, Also some washers use a flow meter that checks water flow.
    May 03, 2017 | Samsung Washing Machines
    Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
    Here is a list of errors for your machine.
    I hope they help you.
    SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
    When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
    1. WATER SUPPLY ERROR - Display shows 4E.
    2. WATER DRAIN ERROR - Display shows 5E.
    5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
    3. OVER-FLOW ERROR - Display shows oE.
    Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
    4. UNBALANCE ERROR - Display shows UE.
    Laundry load is unbalanced, manually loosen any tangled laundry.
    If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
    5. WATER HEATER ERROR - Display shows HE, HE1.
    HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
    6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
    * Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
    Normal Level = Abnormal W/L Frequency
    Low Level = 30.00 Khz
    High Level = 15.00 Khz
    If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
    7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
    e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
    At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
    8. WATER LEAKAGE ERROR - Display shows 11 E.
    Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
    9. THERMISTOR ERROR - Display shows tE
    Nov 21, 2010 | Washing Machines
    E4 error after attempting to fill and get to temp
    This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
    Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
    1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
    2.Make sure probes are clean.
    3.No water pressure — main water supply valves may not be working.
    4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
    OFF-ON procedure.
    5. Delime machine.
    Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
    Hotpoint Aquarius WMA42 Front Load Washer Logo
    15 people viewed this question
    Top Hotpoint Washing Machines Experts
    puggy666
    Level 1 Expert
    freddyfox
    ptpumpman
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
